T-rex Need Oil Pump???
Im Building A Cam Only Ls1 With A T-rex And Was Wonderig If I Should Put In A Ported Ls6 Oil Pump B/c It Will Be Spinning Around 6000rpm, Or Will The Stock One Be Sufficent?
Originally Posted by ablakez28
i dont know i run the stock timing chain and oil pump have been doing so with 2 different cams and almost 10k miles. this includes the t-rex i am running now
Originally Posted by BuckeyeROC
You'll be spinning A LOT higher than that. About 7000-7200 rpm. I'd get a ported LS6 oil pump for sure.
King of Pigskin Knowledge
It's a gamble spinning the stock shortblock that high, no doubt. I installed ARP rod bolts b/c that is the weakest link. After that, I believe the rods are about at their limit.
