Newest (Feb 22) oil analysis from my C5 using German Castrol
Old 02-22-2005, 08:33 PM
ynkssws6's Avatar
Originally Posted by v8maro
how can I tell if it's german??
https://ls1tech.com/forums/general-maintenance-repairs/274691-german-castrol-oil-pic.html A little thread i started to help patman out cause he's helped us all out so much!!
Old 02-22-2005, 08:41 PM
equandt's Avatar
It comes with free weinerschnitzel.
Old 02-22-2005, 09:59 PM
LS1 Swapper's Avatar
Originally Posted by Crash 02
Is it better for the LS1 than Mobil one 10w30?
Originally Posted by Patman
Yes indeed!
Curious why do you state that it is indeed better? What data do you have to support this claim? Aside from the 10w30 vs 0w30 which can be good or bad depending on your climate.
Old 02-23-2005, 12:28 AM
LSWannabe's Avatar
Patman, you were running the short filter?
Old 02-23-2005, 04:35 AM
Patman's Avatar
The reason I say this is after viewing quite a large number of oil analysis reports for LS1s using Mobil 1, compared to this oil. None of the reports using Mobil 1 have come close to the low engine wear that this oil shows. I also found the same drop in engine wear when I switched my sister's 99 Civic over to GC from M1. And many others on BITOG also saw big improvements in engine wear when switching from M1 to GC. It's simply a much better built oil. European oils usually are much better since they need to pass much more stringent specifications.
Old 02-23-2005, 04:36 AM
Patman's Avatar
Yep, it's the only one I can run on the C5 since the long one would be way too close to the ground.
This also shows that if you're running the K&N oil filter, even the smaller version can do a fantastic job. I'd still run the longer one if I was able to though, since it'll hold more oil and it'll definitely flow better.
Old 02-23-2005, 08:34 AM
GuitsBoy's Avatar
If it's got the same specifications listed on the label, it should be exactly the same, however I'm not so sure if this stuff even exists since I have only heard of a couple of people who claim to have spotted it.
It definately does exist. The USA made good stuff was my first time out with GC. It was the week after first reading about the new american made stuff. I popped the cap to make sure it had a greenish tint. I didnt know it would almost glow irridescent green! Anyway, the label didnt have yellow in it like the normal american made crap, which was also mixed in on the shelf. Next time I went they had the made in germany stuff which had an almost identical label as the good american.
Since this stuff does truly exist maybe we should stop calling GC german castrol, and start calling it green castrol???!!!
-T
Old 02-23-2005, 08:35 AM
v8maro's Avatar
So what oil filter should I use for this oil?
Old 02-23-2005, 05:56 PM
ynkssws6's Avatar
Patman recommends K&N
Old 02-23-2005, 07:02 PM
8-Pack's Avatar
I'm not sure which one is European car formula though, other than possibly the 5w40 version, which is made in Belgium.
Its a 0w30, just says european car formula on the front, havent check the back to see if it is made in germany.
Old 02-23-2005, 09:53 PM
v8maro's Avatar
Anyone have the p/n for this filter?
Old 02-24-2005, 12:19 AM
  #32
LSX Mechanic
Damian's Avatar
Old 02-24-2005, 01:01 AM
  #33
psykoTA's Avatar
Its in his first post.
Whats the number for the long K&N?
Why is 0w-30 better than 5w-30?
Would a higher mileage car benefit more from a thicker oil, 10w-30?
I ask all the questions, because you seem to be the man at oil and LS1's.
Old 02-24-2005, 03:50 AM
  #34
LSWannabe's Avatar
Long filter is HP2006.
Old 02-24-2005, 04:28 AM
  #35
Patman's Avatar
The 0w30 flows better in extreme cold, but it's not necessarily the fact that this oil's got the 0w rating which makes it work so well compared to other 5w30 oils. A big part of it is that it's viscosity at 100c is 12.2 cst, versus 10.0 for Mobil 1's 5w30 and 10w30. Most other 5w30 and 10w30 oils out there are also close to 10cst too. This is why this oil would also be better for higher mileage vehicles. That thicker viscosity at operating temp means it will consume less oil and it protects the engine better at higher oil temps. This oil is actually very close to being a 0w40.
Old 02-24-2005, 01:27 PM
  #36
pewterta's Avatar
its a cheap ***! and is always worrieida bout money
Old 02-24-2005, 01:43 PM
  #37
GuitsBoy's Avatar
I think youve got your racial stereotypes mixed up. As unfunny as that was to begin with, its just been knocked down a few pegs. Not cause of the race thing, just cause it makes no sense.
Old 02-24-2005, 01:50 PM
  #38
psykoTA's Avatar
I was wondering what he meant
Thanks for the info Patman. So a 0w-30 castrol synthetic is the way to go. Do you have a analysis of Mobil 1, in the same car? I am wondering if this oil is good enough to switch from Mobil 1.
A quick theory question: Would an engine using castrol 0w-30, see more mileage than an engine using Mobil 1 5W-30? Assuming both are drivin the same, and in the same climate, etc.
Old 02-25-2005, 01:15 AM
  #39
LSWannabe's Avatar
Dont forget we're discussing German made Castrol syntec 0w30. Not American.
Old 02-25-2005, 04:40 AM
  #40
Patman's Avatar
I switched my Corvette to GC as soon as I got it, so I don't have a comparison to Mobil 1 from this car, but I did run Mobil 1 and then GC in my sister's car, and engine wear was lower, especially the bearing wear.
In theory when you've got lower engine wear on your analysis, this means your engine will last longer. By how much, who knows? But I'd definitely rather see the lower numbers! Keep in mind too, that most people on here would probably never wear out their engine no matter what oil they run, since most people don't go more than 100k before getting a different car. But if longevity is your priority, go for the best oil you can find.
Quick Reply: Newest (Feb 22) oil analysis from my C5 using German Castrol
