Dropping the Motor... (Help)
Old Feb 23, 2005 | 09:26 AM
ABadMother1999's Avatar
Default Dropping the Motor... (Help)
Hey I did a search on "Dropping Motor" and I couldnt really find any detailed write-ups or advice or a step by step process. I am curious as to if there is any write-ups and if so could u please post them. Also I was curious as to your suggestions on whether I should pull it out of the top of drop it anyways. Thanks for all help!
John
Old Feb 23, 2005 | 09:53 AM
jrp's Avatar
jrp
SN95 Director
you wont find may detailed write ups. i pulled mine as a shortblock from the top and pulled the whole k-member setup from the bottom. installed everything back in from the bottom.
use these for reference
http://www.michiganspeed.com/enginepull/index.html
http://ken.lowrance.com/Projects/Hea...ineRemoval.htm
Old Feb 23, 2005 | 11:50 AM
Thanks JRP... I found these to be pretty helpful and I will be dropping my motor sooner that I thought I think lol. Well more input is welcomed and recommended... Thanks in advance!
Old Feb 23, 2005 | 12:10 PM
jrp's Avatar
jrp
SN95 Director
dont **** up . its not overly hard, just a bit time consuming the fiirst time out and just make sure you have all the right tools.
heres how i did mine
https://ls1tech.com/forums/showpost....22&postcount=8
Old Feb 23, 2005 | 02:21 PM
Thanks.... I like visuals, they always help clear up the confusion! Thanks again!
