splain the difference
Old Feb 23, 2005 | 03:00 PM
Vertigo's Avatar
Default splain the difference
Whats the difference b/t a solid roller cam and a hydrolic cam?
Old Feb 23, 2005 | 03:03 PM
Wnts2Go10O's Avatar
the search button, there was a post on this like an hr ago
Old Feb 23, 2005 | 03:16 PM
777's Avatar
777
https://ls1tech.com/forums/generation-iii-internal-engine/280662-solid-roller.html
basically solid roller is for track cars...a lot more duration cam's...you can spin a lot higher safely...but you have to set lash every so often...
Old Feb 23, 2005 | 03:17 PM
jrp's Avatar
jrp
SN95 Director
i wouldnt doubt it
hydraulic cam: a cam using lifters that has a valve-controlled plunger inside its body, preloading the pushrod at the closed valve position through oil pressure lift: distance the valve is depressed from its seat when closed to the peak valve lift when open fully
mechanical (solid) cam: a cam using lifters with only a radiused contact face in which the pushrod end sits without internal valves or other complexity; requires periodic lash setting
