408 stroker guys inside please
Old Sep 3, 2005 | 01:14 PM
destroyerSS's Avatar
i'm using a baby cam for my 408 253/257 642 646 112
Old Sep 3, 2005 | 01:46 PM
Black8Banger's Avatar
I am looking at the ZL-402 form SLP and they told me that with AFR 225s 62cc heads that the most lift you can run without modifiying those 6cc dish pistons was .596 anyone know if this is true? Based on those lift numbers Comp cams recommended a 242/248 .593/.595 112 for my 402. Anyone else had this experience?
Old Sep 3, 2005 | 04:09 PM
BlueSix's Avatar
Originally Posted by dame
im getting ready to finally pick out my cam and was wondering if there were any new 408 owners out there that might be able to contribute
Im kinda leaning towards something small but will utilize a set of TEA ported AFR's (with a 2.10 intake) to the best of its ability.......
Do small cams (in terms of a stroker) with BIG LIFT (.615-.625) even make sense? any and all info will be greatly appreciated.
I would stay away from the AFR heads that have been worked by TEA....i have yet to see any good results from them. I would put the extra money from having the heads reworked into something else.
The out of the box AFR 225's (i'm guessing with a 408 that you'll be using the 225's) will be more than enough for a 408 with a small(er) cam.
SiL3NtXWS6's Avatar
261 / 267 .646 / .639 113LSA here.
Old Sep 3, 2005 | 07:11 PM
Sn8ke_Eater's Avatar
Really? So what BAD results have you seen?
Old Sep 4, 2005 | 12:11 AM
dame's Avatar
Can you explain please?... how many "bad ones" have you seen?
Old Sep 4, 2005 | 01:33 PM
BlueSix's Avatar
Do a search on the user name PDD. He has TEA worked AFR 205's and i don't think he's gotten the expected numbers from them yet. Also... https://ls1tech.com/forums/showpost....&postcount=164 $3700 in heads and not even making 500 at the wheels with a 408. The extra grand it will cost for TEA to rework the heads can be better spent.
Old Sep 4, 2005 | 01:35 PM
BlueSix's Avatar
https://ls1tech.com/forums/dynamometer-results-comparisons/372226-dyno-numbers-slp402ls2-afr-heads-ported-tea.html
Barely making 450 at the wheels with TEA worked AFR's on a 402.
Spend the extra grand elsewhere.
Old Sep 4, 2005 | 03:08 PM
hey dame what about a 232/234 with a 6xx/6xx lift hehehe i already know sounds sweet
Old Sep 4, 2005 | 05:03 PM
O2bqwik's Avatar
im running a 250,257 .630 .645 112lsa i was orignally going with a 243/250 but it sounded a little too tame for me
Old Sep 4, 2005 | 05:52 PM
Boostaholic's Avatar
I switched from TREX to a mild 230's 560lift cam, 114lsa for my turbo application.
Old Sep 4, 2005 | 06:33 PM
  #32
j4nash's Avatar
I will be trying his cam that i have in my 6.0 when i do the 408 swap in my truck 220/226 556/570 114+4
Old Sep 4, 2005 | 06:49 PM
  #33
BLK02WS6's Avatar
UPS man just brought my Texas Speed "Giant" 248/254, 614/613, 113
It came highly recommended, I hope it works out for me. My heads are being ported locally - flow numbers looking great so far.
Old Sep 5, 2005 | 12:00 PM
  #34
dame's Avatar
https://ls1tech.com/forums/showthread.php?t=372226
You HAVE TO be kidding me.......did u NOT NOTICE the long tubes he's using, or the lack of a 90/90 setup...... LMAO plus the T REX was designed for stock headed cars....isn't going to "shine" on a built setup IMHO
We have a guy in our club (reboot on here) that put down 488 AT THE WHEELS in a 382 with those heads and a 232/236 114 LSA cam (TEA ported afr's)
as far as PDD's car... I dont know the specifics on that.... but I DO KNOW im not sending TEA a set of 205's to be "reworked"..... they are are actually putting their "program" on a set of AFR "blanks" for my setup. which I would assume is different than picking up someone elses work and trying to rework that.... but hey I dont know im not a head porter.
Old Sep 5, 2005 | 12:10 PM
  #35
Bryan @ Speed Inc.'s Avatar
I HAVE YOU ALL BEAT WITH THE SMALLEST CAM haha. i'm running a 402 (does this still count?) anyways... i have the MTI stealth 2 grind cam. 224/220 116lsa and .581 lift. the cam idles STOCK and gives a fat torque curve makes power off idle to about 6,500. 6spd through a 12 bolt w/ 33 spline axles, 4.10 gear, and a posi made approx 440+ at the wheels w/ patriot heads and a fast 90/90 setup.
Old Sep 5, 2005 | 12:11 PM
  #36
it's cool to have violent power everywhere in the rpm range and idle lick stock....... but i want to go with a much bigger cam.
Old Sep 5, 2005 | 12:14 PM
  #37
dame's Avatar
Originally Posted by imslow
I HAVE YOU ALL BEAT WITH THE SMALLEST CAM haha. .
yes you do sir......YES you do!!! nice power btw!...Im going small.......but NOT that SMALL! lol
I BET THAT THING PULLS LIKE A FREIGHT TRAIN! what's your exhaust setup? and are you going to spray your setup?
Old Sep 5, 2005 | 04:20 PM
  #38
thanks for the compliments... it was tuned by SPEEDINC. so i give them credit for the numbers. yes the car does pull like a freight train. my exhaust is a simple set up... i have flowtech l.t.'s and o.r.y. and a hooker catback. i want to eventually go with a monster cam.. but funds are TIGHT right now. and no i'm not planning on spraying the combo anytime soon. again with the $$$
Old Sep 5, 2005 | 04:26 PM
  #39
dame's Avatar
wow! u put up some real good numbers (IMO) for not having 1 7/8th QTP's
Old Sep 5, 2005 | 06:31 PM
  #40
anyone know how i can find out what the highest lift cam i can run is? setup will be a 402 with 6cc dished pistons and AFR 72cc heads.
By Brett Foote | 2026-06-04 05:00:17
