Cams Around .632 Lift
Old Feb 26, 2005 | 12:41 AM
1fstGM's Avatar
Restricted User
Default Cams Around .632 Lift
What set up are you guys running this cam on? Are there any modifications to be done as far as clearance?
Old Feb 26, 2005 | 07:58 PM
1fstGM's Avatar
Restricted User
No one is running a cam of this nature?
Old Feb 27, 2005 | 01:30 AM
NataSS Inc's Avatar
On a stock inch motor.....NO (unless its solid roller). There are maybe 2 or 3 hydrolic cams available that even close to that. I dont know alot about big bores but I am sure there are a couple out for the big bore motors.
Old Feb 27, 2005 | 02:51 AM
TheBlurLS1's Avatar
That's what she said...
if you are wanting to put that cam in your 6.0 motor w/ 6.0 heads, i'd say dont even think about it. why do you want to run the 1.85 SLP rockers anyway? sure they will hang that valve about a mile outa the head, but unfortunatly for you, the piston wont be at least 1.00001 miles away at this point in time
camshaft lift isnt everything my friend, i've heard all the talk at the dirt track too lol
redneck1- "that thangs gotta .750 lift cam in it!"
redneck2- "i bet it'll go around the moon wiff enough carburrtrator on it!"
the thunder racing t-rex isnt close to that size, and its a MONSTER! keep on researching, reading, and learning. check out JRP's signature, he's got a nice cam guide writeup in there.
Old Feb 27, 2005 | 08:59 AM
PREDATOR-Z's Avatar
Yeah, slight modification necessary, like stroking an iron block
(provided you are talking lifts at .050).
Old Feb 27, 2005 | 06:47 PM
1fstGM's Avatar
Restricted User
The motor is stroked, it is a 391.
Old Feb 27, 2005 | 07:38 PM
DavidNJ's Avatar
By and large, the people on this forum seem to be running .580-.600 peak lift hydraulic rollers. The vary widely in duration though, with some posts indicatiing people are pushing the drivability limits...especially with stock displacements.
When you go to higher lifts you need to be careful about piston to valve clearence. You will need to check. Probably need to flycut. And may need different pistons if the flycutting would be excessive.
You will need springs that can handle it, which you may or may not already have. The faster ramp and greater motion will also cause the springs to wear out quicker, requiring changes.
Most of the LS1 heads have reached 80% of their peak flow by .4", and don't gain flow above .6". So, unless the larger lift is allowing greater duration at .200" lobe lift (for the same .050" lobe lift number), it isn't really buying you much.
David
Old Feb 27, 2005 | 08:54 PM
NASTE_SS's Avatar
My cam is just under .632 at.050. what is the Lsa, and the duration ,intake and exhaust at.050. my cam is cut at a very wide LSA and it fits very close with about 60 on intake and 90 on exhaust. There are a lot of factors that play a role in clearancing the cam so let me know the specs and i can check it out for you.
Old Feb 28, 2005 | 12:20 AM
1fstGM's Avatar
Restricted User
The LSA is 112 and the duration is 250/256 at .050. Can't I just turn the crank manually to see if the valve will clear the piston? The pistons are diamond and have a -2cc valve relief. The heads were flowing around 319 @ .600 just FYI. Thanks.
Old Feb 28, 2005 | 11:34 AM
TheBlurLS1's Avatar
i dont think the duration on the cam is going to be magnified like that by the 1.85 rockers. post up the actual cam specs (like they show you with 1.7 rockers) like you did in the other thread ya started
Old Feb 28, 2005 | 12:08 PM
Ben R's Avatar
Higher ratio rockers decrease the amount of time it would take the cam to get from .020" lift to .050" lift to .200" lift to .300" to .400" and so on. They will affect the seat-to-seat duration of the cam VERY slighty. It's usually only about 1 - 2 degrees of duration. Generally, they are used to increase the ramp rate, or when we've got good valvetrain pieces, we'll use a higher ratio rocker and a smaller lobe lift to achieve our big lift, instead of using a big lobe lift and a smaller rocker.
Lift has no affect on PTV. Duration, cam timing, lobe type, and LSA, among other things, however, do affect PTV. Remember, more LSA = more PTV. You could put a 1.000" cam into your stock LS1 and have no PTV issues. Not saying that stuff exists, but it's a good example.
More lift isn't always going to make more power, but it rarely hurts power. But to answer the original question, .632 lift is do-able on a hydraulic roller setup.
Old Feb 28, 2005 | 04:20 PM
1fstGM's Avatar
Restricted User
The orignal specs on the cam are as follows: 112+2 250/258 .580/.580 all at .050
Old Feb 28, 2005 | 04:58 PM
Big-DEN's Avatar
Yup,
Some of these bigger or big block heads keep increasing in flow all the
way up to 1" of lift. Damn that is big...
Another thing is just because flow drops a couple of CFM at the next .1" increment of lift doesnt mean you are going to lose power.
You gain power from lifting out that far because you hit every flow point earlier than you would if you didnt. Getting lift fast is important on the intake side of things.
Dennis
Old Feb 28, 2005 | 07:25 PM
MOTRUBL's Avatar
251/257 .628/.645 114 in a 422 iron stroker
Old Feb 28, 2005 | 08:44 PM
1fstGM's Avatar
Restricted User
Where did your car hit peak power? What did it dyno at?
Old Mar 1, 2005 | 08:09 AM
koolrayz's Avatar
240/246 .635/.625 on a 114. just got it running havent been to the dyno yet
Old Mar 1, 2005 | 09:14 AM
PREDATOR-Z's Avatar
Rayz, why didn't you choose more exhaust lift split? I thought that would be better for nitrous?
Old Mar 2, 2005 | 08:00 AM
koolrayz's Avatar
The heads flowed crazy exhaust numbers (280@.600) on TEA bench That and the big headers were the reason for the cam choice
Old Mar 2, 2005 | 09:18 AM
PREDATOR-Z's Avatar
280 exhaust, holy batshit Batman.
You're sure you don't want to add a chute to slow down after the line
