FMS F13 questions
Originally Posted by LS1_PNYTAMR
hmm... what does the f13 112 off the shelf peak at? im not looking to shift to high.. if i have to shift at like 6800 that would kill my n2o times since i have to stop spraying at 6000ish'.. im looking to shift more like 6200-6400 on the n2o, and maybe 6500ish on motor? im ordering mine tommorow is there a certain way i should ask it be done? or should i just set the shift points on nitrous at 6100 with this cam, and let it shift where it needs to on motor?
![](http://www.slowls1.net/images/blake_FMSdyno.jpg)
Check out the dyno section and do a search for my name. I have posted my graph of Allan tuning my F13 cam only and I have a vid of me on the dyno with my cutout open.
Originally Posted by FstBlkz28
those M6's w/ the fm13 ... what gears are u guys running? stock 3.42's? or did u jump up to 4.10s?
and also, whats the diff b/w the 112 +2 / +4?
check sig
I'm running stock gears and my F13 is a 112+2. I've been driving it daily since the cam went in last summer without any problems, driveability is great. Dyno graph here: http://www.slowls1.net/images/f13.jpg
Please be aware that 430/414 cam-only is not the norm for this cam. I'm not doubting Kalijah's numbers, but his numbers are the only ones I've ever seen anywhere near that high. I would guess you can expect to be in the 390-410rwhp / 375-395rwtq range depending on mods and tune.
#32
Originally Posted by TIMMEH
how much is this cam going for?
I beleive the cams are going for $340 and they also offer some great packages.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
edit: or what he said above
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#33
#34
Originally Posted by ssheets
They are on sale right now..it was posted here yesterday and I have the link saved at home (I can't find it right now)
I beleive the cams are going for $340 and they also offer some great packages.![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
edit: or what he said above![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#36
linky FMS Sale
Trust me , my f13 cam can be heard and sounds awsome with the cut out open. I shift at 6700 and the car does not stop pulling untill 6800 with the 112+4 f13.
This cam makes more power and tq then my old c1 cam at every rpm . See sig for last fridays track times on m/t drag radials.
#38
Originally Posted by Nsty98LS1
does anybody have any dyno or track numbers for an A-4 car. i've tried searching and can't seem to find any for A-4s. seems most people running this cam are M-6.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#39
so if i get this cam on a 114 +4 where should my peak numbers be? with my mods so far and ones coming with cam swap, what would be a good estimate of how much i should dyno and what kind of times and mph should i see at the track(assuming i hook it up)? i would like to be in the low12s with decent drivability, it's my only ride, or am i asking for too much?
#40
