What is the best No2 Cam
What type of exhaust are you running? I remember seeing a nitrous fed reverse pattern camshaft gaining 60rwhp w/ dual cut-outs engaged.
In fact...
http://img.photobucket.com/albums/v4...ls1/bottle.jpg
1 3/4 MACs portmatched and cleaned primaries, with collector mod, custom 2.75' ory and cutout.
I didn't think that the Stealth would take over 125>150 shot but because of the 116lsa (-10* overlap) it did. And just a reminder, this is a "reverse split" 224/220, daily driven, emission passing little cam.
I shoot 200 dry on a 224/220 116+0 with excellent results.
Back TTT, FM 7 and FM9 are good for big shots.
A nitrous cam is only so after ~ 150 shot.
The FM grinds Predator mentioned shoudl work good as well as a few other off the shelf grinds. I had good luck with FM7 in a 8 psi Procharged stock longblock car, 550 rw
Take for example.
A n-a "street" setup using a 110* lsa. It could use more overlap but again, the user wants street manners.
So when a 200 shot is used, does the overlap need to be less? I see it as no. Seeing as a tighter ld could have been used for the n-a setup. Why widen the lobes when they are already wide, for meeting the users street requirements?
Seems a lot use wide ld's just because they have been warned of shooting out boost, nitrous or w/e the occasion.. out the tail pipe.
opinions?
After so more inquiring, I came to the conclusion that wider lsa and 0 or negative overlap cams are more forgiving tuning wise, while running N2O.
Also, I'm starting to see more clearly that VE's matter much more than LSA in a nitrous cam denomination.
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
