G5X3 Results inside.
Old Mar 4, 2005 | 07:55 PM
TINKRD's Avatar
Default G5X3 Results inside.
G5x3 Results Inside.
Well I'm going to drop by LG next week to see what LG thinks.
I'll let the #'s speak for themselves.
Before:
228/228 588/588 114+4
376 HP / 367TQ
I dont remember what timing was set at.
After:
Only performance mods added were G5x3 and ASP UD Pulley.
2??/2?? Duration & 600/610 Lift at 114+4
385 HP / 360 TQ
26 degrees timing for N20
I know #'s arent everything but I am a little disappointed. Tomorrow I'll fill the bottle up and see what she'll do.
The rest of my setup is in the sig.
Old Mar 4, 2005 | 08:06 PM
Squintz Palladoris's Avatar
List you Mods an transmission/drivetrain.
Then whats the AFR
And if ya have a graph that would really help.
Brad
Old Mar 4, 2005 | 08:17 PM
ssheets's Avatar
Then whats the AFR
Brad
His mods are in his link;
Current Mods:
Induction-
SLP High Flow Lid
Shaner Ported Throttle Body
Throttle Body bypass mod
K&N Filter
LS6 Intake Manifold
Valvetrain-
21st Century Muscle Cars cam
228/228 588/588 114 lsa
Comp 918 Springs
Exhaust-
Borla 3'in cat-back
SLP LT Headers
SLP 3'in Y-Pipe (ORYP-no cats)
3'in Exhaust Cut-Out
Tranny-
Lou's short throw shifter arm
SLP short throw shifter
SPEC Stage 3 Clutch
Upgraged GM Slave Cylinder (new-06/04)
Drivetrain
Moser 12 Bolt (new-08/04)
33 Spline Axles (new-08/04)
4.10 Gears (new-08/04)
Eaton Posi (new-08/04)
1350 Yoke (new-08/04)
Old Mar 4, 2005 | 08:33 PM
kkholiday's Avatar
<---- Jaypee1217
I dont have a scanner, but I will take a pic of it tomorrow and post up.
Old Mar 5, 2005 | 01:38 AM
prostock_bigblock's Avatar
Old Mar 5, 2005 | 11:48 AM
TINKRD's Avatar
here's a pic of the graph
Old Mar 5, 2005 | 11:56 AM
InsomZ's Avatar
that 12 bolt w/ 4.10's will eat up around 10rwhp but its worth it when u're getting down the track
Old Mar 5, 2005 | 12:07 PM
TINKRD's Avatar
this was the last dyno w/ the 228/228 cam.
Old Mar 5, 2005 | 12:08 PM
TINKRD's Avatar
Acutally going from the 10-bolt to the 12, i only lost 5 RWHP, but i did lose 25 ft/lbs of TQ.
I just dont think that going from a 228/228 to the G5x3 would have only picked me up 9 HP and a lose of 6 ft/lbs of TQ.
Also remember I added the ASP UD pulley too!
Old Mar 5, 2005 | 12:18 PM
Ravenous T\A's Avatar
I did 392rwhp with my G5X3 at Fastech
JMBLOWNWS6's Avatar
Its all good. Go down the track and see the results The hell with the dyno #'s. Did Chris robinson tune it?
Old Mar 5, 2005 | 12:42 PM
TINKRD's Avatar
yeah chris r. tuned it.
I'm setting up a race today, w/ the old cam me and my buddy were dead even from a 50 punch, so we'll see what happens this afternoon.
Old Mar 5, 2005 | 02:53 PM
8banger's Avatar
Let us know how that race turns out....should be in your favor. Anyways, look at it this way, you have more top end and that torque looks really nice. I think it'll prove to be worth it.
Old Mar 5, 2005 | 03:25 PM
DanZ28's Avatar
Did you do any data logging for KR?
Old Mar 5, 2005 | 03:43 PM
jrp's Avatar
jrp
SN95 Director
something is off, 350rwtq @ 4k and a peak @ 6200.
Old Mar 5, 2005 | 03:53 PM
black_z's Avatar
Was the cam degreed in? Are you still running the 918's?
Old Mar 5, 2005 | 08:03 PM
TINKRD's Avatar
i have no clue how the tuning was set up, i didnt get there until it was off the dyno rack and on the ground.
i'm running PRC v. springs now.
Old Mar 5, 2005 | 08:25 PM
goober35's Avatar
Time to do a comprtion test. Do you have cats. What wheels and DS do u have. If u have 18in wheels and a steal drive shaft and a 12bolt with 4.11 you can eat up some power. Maby 20-30hp if not more if you have cats and some heave Drive train parts.
Think about it.
Old Mar 5, 2005 | 11:03 PM
kkholiday's Avatar
i have 17 in wheels, 3 in steel DS and no cats... but with the 228 i pulled 376, it just doesnt make since to go from 228/228 588/588 to the g5x3 PLUS a asp UD pulley and gain only 10 HP and lose 6 TQ. i am going to do a compression test this week.
Old Mar 6, 2005 | 01:45 AM
Tranzor's Avatar
The numbers don't sound too bad, honestly... as long as you have some stuff that eats up HP on a dyno. For instance, I dynoed 381 rwhp and 351 rwtq with my TSP 231/237 cam.
Full bolt-ons only I did 336 rwhp, 336 rwtq, which was with an ORY, but dynoing through a 12 bolt with 33 spline Eaton posi and 4.11 gears. So my car dynoed low to begin with...
Also, in addition to adding the cam between dynos for me, I also added a heavy Denny's NR driveshaft, went from 16" wheels to 17" wheels, and added a catted y-pipe... all of which can take away power.
Had I dynoed with my old 16" wheels, the stock aluminum driveshaft, ORY, and a 10 bolt with 3.42s, I wouldn't be surprised at all if I hit 400 rwhp and 375 rwtq. But all those other things I added are for getting down the track, not for big dyno numbers...
