228/230 571/573 112+4 lsa
Just bought this cam...
tried to search but didnt come up w/ much so I have a few questions..
What HP can I expect w/ stock heads on a bolt on A4 Car?
Whats the +4? haha probably need to know b4 i bought the cam right...
I want to run n/a good and 100 shot good.. Will it be good w/ both? Better for which?
918's should be good for this right?
hardened pushrods
titianium retainers
anything else?
Also I have seen a lot of good things about the 224 cams making more usable power than the larger ones...
This is a daily driver will I be ok? Probably going w/ a 3200 or 3500 md stall...
thanks for any help
hardened pushrods
titianium retainers
anything else?
thanks for any help
This is the biggest shelf grind from Comp Cams has before going to the XE-R grinds and should make great power. The +4 should mean that its 4 advance which makes it on a 108 icl based of off the 112 lsa. I would guess 360 or so at the ground without knowing other details. I personally like this cam too.
thanks...
sorry for all the questions and I tried typing in the cam but it brought up everything but it lol...
Im happy its a good cam... A guy at speed demon had it for sale really cheap so i just jumped on it..
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
oh one more important thing...
The 112lsa and me spraying a 150-200 shot... How bad is that 112lsa? I mean will it work better than stock just not as good as a 114 or is it just bad?
Originally Posted by Bo White
Do you want it to run good on the spray or on motor? My rule is build the engine to run N/A and then spray what ever you want for a street car.
And if it a 150 shot will do just as good w/ this cam as the stock cam then im good...
