rocker arms/pushrods..the final details.
So to the meat of my concern..The heads I'm getting have been milled .030".
Conventional wisdom says I should go with a set of .025" shorter pushrods,but I've been told that stock length is ok..Why did comp make them if stock is fine?
Okay the next thing I'm fence sitting on is rocker arm choice..
Im torn between YT's & Comp RR adjustable.
The cam I'm using is a 222/222, 566"/566" on a 112. I have given som thought on putting 1.8's on the intake & 1.7's on the exhausts..It's an old SBC trick that I dont know if its made its way into mainstream gen III acceptance or not.
Im running 918's with perimeter bolt heads..I've heard of after market RR's interfereing with either/or perimeter/center bolt valve covers.
Whew..
Experience/knowledge appreciated..
I didnt even get a search button **** response.
On thing that no one's been able to answer...
Why switch to an adjustable valve train?
I assume GM went non adjustable on GEN III's for emissions compliance reasons.
As if to take one more variable out of an incompetent machanics hands to screw up driveability.
Why undo this by installing aftermarket adjustable rockers?
They said they milled 'em .030" & it's still ok to run stock pushrods...I am trying to get a second opinion based on people's experiences.
What I'll probably do is just get the car running with known good components(stock rockers /pushrods) & take it from there..I just thought it would be cool to have it all set up before the engine goes back in..It's alot easier installing that stuff without a car around it.
Now to anyone using an adjustable rocker.
Is the method for adjustment the same as a SBC/BBC?(adjust until all slack is gone/in a pattern based on fireing order?)
I figured Id put this here rather that start a new thread about blown motors..
What's not visible is the empty #7 bore where a piston is supposed to be.(it all ended up in the oil pan)
What happened???
Raw stupidity.
