Nastysupaspt's H/C buildup pics(Not 56K friendly!!)
(Edit: Dyno #'s inside now)Nastysupaspt's H/C buildup pics(Not 56K friendly!!)
I hosting some pics for another forum member "nastysupasptss" . His H/C buildup was done by Ron Williams and just completed 2 days ago. He is still letting the clutch break in but it should be a ton of fun once it is. Here is the setup:
2002 Camaro SS
Lid/filter
asp pulley
hooker longtubes
ORY pipe
Corsa Exhaust
Granetelli maf
LS6 Style heads w/ 63.5 cc chambers
Comp cam 236/236 .595/.595 112lsa
LS6 ported high flow oil pump
double roller timing chain
chromoly pushrods
Spec 3
Spec 3 billet flywheel
stock intake manifold
stock rear end
stock tb
he is hoping for power in the 430whp range. Here are some pics for him. Chime in Damian when you get a chance.
2002 Camaro SS
Lid/filter
asp pulley
hooker longtubes
ORY pipe
Corsa Exhaust
Granetelli maf
chromoly pushrods
Spec 3
stock rear end
stock tb
I heard this car at an idle, and it sounds insane. I have no cats, and no "real" muffler, and I couldn't even hear my car while we were driving down the street. This is the way a car should look and sound! Congrats Damian...and Doug said he'll run you first! I'll wait to see the results!
Originally Posted by GuitsBoy
If you guys thought the RTV on the header gaskets was a little strange...
What about lubing up the double roller timing chain with loc-tite ???
Originally Posted by LSUxBlake
Looks like the Engine Assembly Lube from Comp to me.
Ha, ha, it is engine assembly lube. That was pretty funny. Mechanic is a big boy with a bad back. It takes him about 1.5 hrs to drop the motor and he prefers to do it this way for the ease of not having to lean over the motor is all.
thanxs alot guys especially to doug and ron (the Mechanic) for the help. i love how the car runs and sounds. but like doug said i have to break the clutch in yet. Then we will see some dyno numbers. I tell you what though it is great when a mustang pulls up to you and says he doesn't wanna run cause the car sounds sick.
i have to ask u guys does any body run after market motor mounts when running over 400 hp. and if so what company carries them? cause ever since the h/c package the motor tq's like crazy. which is kinda cool
I'm just buttoning my baby back together from a similar project and I replaced my motor mounts with polyurethane ones from Energy Suspension. I think they were 40 bucks, I got them from Summit.
