TR224, your thoughts on LSA?
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
wont kill you just sounds like you have it modified. The power untuned feels good you can tell it just wants to open up past 5k rpm. Idle will be smooth almost like a the stocker. Dont think all is perfect the car has trouble stayin on sometimes with the A/C on. It runs richer. And it needs bolt ons to make it shine. Havent dynod or taken it to the track, but most will tell you the same this is a proven cam for both strip and street, auto x or drag. Good luck with more info, the techies round here can help you with info I dont have. Trending Topics
i was afraid the idle would be to choppy but its great.my buddy has a fm11 on a 114 with 4 deg advance and his idle is just as choppy.and our cams have almost the same lift and duration.and everything iv'e read says the 112 has more torque down low than the 114.the 114 will peak a little higher the fm11 on his car peaks at 6600 and mine peaks at 6400 but holds it to 6900 his holds to 6900 also
Four valve events happen in every 4 cycle motor. Intake valve opening/closing and exhaust valve opening/closing. One must consider these events to really talor their power band to their liking.
it seems like stock from 0 to 3000 RPMs. from 3000 to 6000 it's fun
with the 114 LSA, you can tell the car has a hint of something going to.
with the 112, there's no hiding you have a cam.
go with the 114 and a set of AFR and you'll have 410 RWHP
"it changes the most-efficient speed range. An engine that has a camshaft with a smaller lobe-seperation angle will generally have better breathing characteristics at higher engine speeds, and typically this results in more top end horsepower and a loss of low-end torque. An engine with a greater separation angle will have better low-rpm breathing characteristics, and this results in more low-rpm torque." -Smokey Yunick's Power Secrets by Smokey Yunick with Larry Schreib
I think this is the correct assumption.
I looked in my Comp Cams Catalog, and they didn't really define how it affects power band, just defined what it was.
A 230/230 110lsa cam with four degrees of advance will have a much earlier power band then a 230/230 110lsa cam with no advance or some retard in it.
