G5x4 cam first impressions.
Old Apr 21, 2005 | 11:30 AM
YsoFast's Avatar
So how would this cam work in a 383 with AS stage 2.5 5.3l heads, 90mm intake bla bla bla? I cant wait!!
Old Apr 21, 2005 | 12:11 PM
PREDATOR-Z's Avatar
It will loose some of its MAX effort characteristics. ie: be tamer.
Old Apr 21, 2005 | 12:49 PM
YsoFast's Avatar
Will 1 3/4 to 2 1/2 (collectors) LT headers be enough for a setup like I mentioned? I am asking because thats the only thirdgen conversion LT for the LS1 so far.
Old Apr 21, 2005 | 02:38 PM
PREDATOR-Z's Avatar
Will make really good lower trq, I mean really good, but upper end will suffer.
Oh and BTW, did you swap a bigger rear in there too
Old Apr 21, 2005 | 03:02 PM
YsoFast's Avatar
Going with a 12 bolt with something around 4.10 in it. I dont want to spin this thing past 7k anyhow so the 1 3/4 LTs might be the better choice. Well its not like I have a choice anyhow unless I get a custom set made for the Iroc.
Old Apr 21, 2005 | 03:04 PM
PREDATOR-Z's Avatar
Going with a 12 bolt with something around 4.10 in it. I dont want to spin this thing past 7k anyhow so the 1 3/4 LTs might be the better choice for. Well its not like I have a choice anyhow unless I get a custom set made for the Iroc.
did you try stainless works?>>>>>>>
Old Apr 21, 2005 | 03:49 PM
Louis's Avatar
Glad you guys like the cam. Its tough to keep it in stock, I know some of you waited a while while they were being ground
Let me know if you guys have questions regarding this cam package.
Louis
Old Apr 21, 2005 | 03:54 PM
YsoFast's Avatar
Yep some of us waiting a while and called every friday to keep you on your toes. lol I am just glad I got it and now the engine build can begin. Thanks!!
Louis,
What do you think about the 1 3/4 header vers the 1 7/8? Is it worth it to get a custom set built for my project in your opinion or with the 1 3/4 set be fine for a street and strip car?
Old Apr 21, 2005 | 05:29 PM
Orange Peel's Avatar
I did install it dot to dot, and have no idea of the clearances, it's close, but doesn't hit, works fine with my stock 853 casting LS1 heads. I have a video of it in here now.
Old Apr 21, 2005 | 05:38 PM
Derek98z's Avatar
didn't see anyone with dyno numbers on this yet. Are you guys running this with stock heads?
Old Apr 21, 2005 | 05:41 PM
Yeah I run it with stock heads and I will be dynoing this Sat.
Old Apr 21, 2005 | 09:36 PM
  #32
xttc2000's Avatar
i think i had one of the very first x4's made.
the car just wasnt finished until recently.
i still think the 224 had more lope to it, lol- but the x4 definitely has more of a punch in the exhaust- the note hits harder is the best way i can describe it.
Old Apr 22, 2005 | 08:17 AM
  #33
Mcduffys's Avatar
I put down 425rwhp/375rwtq with stock ls6 heads here in arizona.
