G5x4 cam first impressions.
so my car is done finnaly and the x4 is in it.
car is a 2000 SS m6
initial thought. wtf? it idles....... and it sounds tame... less lopey than my 224 on a 112 but with more throat to it?
the car is on pretty much a break in tune right now, running very rich.
on the road: cam surge? minimal.
gear: 3.73 definitely needs more
gas mileage: did 274 miles off a fresh tank today, thats driving it at all kinds of rpms NOT in 6th gear on the highway at 2k.
performance: 1st and 2nd gear are wicked, 3rd is alright then it falls on its face in 4th. definitely needs a good tune. ill update this post after that gets taken care of.
would i recommend daily driving it?
Absolutely under these conditions:
- Have the money or skill tools and time to check and change the valvesprings often.
- tall gears are a MUST
- have the supporting mods to handle the cam, and dont complain on here when you break your 10bolt.
- Valve reliefs or flycut, DONT try to run this in an m6 without.
Ill post sound clips this afternoon for those of you interested
This cam is BIG and you can tell, after driving it around more now, been 4 days since I installed it, it will let you know it's there down below 1500rpm, surges some. I don't care about the surge, it still drives amazing, but be prepared to never cruise through a parking lot at 900 rpm in first or second, more like gas, clutch in, clutch out, gas, clutch in, etc, etc. mike
-matt
car is a 2000 SS m6
-matt
