LS6 block ever in a camaro?
Old Apr 18, 2005 | 08:07 PM
deetsnai's Avatar
say ur cam broke.....like women know anything ahhahahahah
Old Apr 18, 2005 | 08:13 PM
SJTrance's Avatar
LOL! I'm cam broke, but I'm far from broke. It's tough modding the car when I'm not supposed to be modding anymore. The wife knows about modding. She's been sitting shotgun with her older brother as he rally raced in Jamaica.
Old Apr 18, 2005 | 10:52 PM
Nick 02 Z06's Avatar
I thought that 10% of 2001 and 25% of 2002 Fbody V-8s came with the LS6 block.
In my oppinion, if you added Z06 heads and cam to a 2001 C-5 Coupe the numbers would be the same on the dyno but at the track, the Z06 would edge out the coupe slightly due to 2 factors:
1. Weight
2. Differences in transmission gearing: M12 in the Z06 and MN6 in the Coupe. An M-12 with 3.42's is more like running an MN6 with 3.90 rear gears.
With a good cam selection (like FM13/G5X2 or 3) on your current setup and an LS6 intake I can't imagine you not being able to walk a Z06.
You wouldn't even need headwork.
BTW, Nice looking ride!
Old Apr 18, 2005 | 10:56 PM
SJTrance's Avatar
I don't think that the gearing in the Z06s are any different. For example, the Z06 and an FRC both have 3:46 gearing. The differential is built stronger in a Z06, but it's not any "faster." However, the weight is something to contend with. I mean, am I really gonna get lighter windows in the car? hehe.
Old Apr 19, 2005 | 02:17 AM
Dan_the_C5_Man's Avatar
He's referring to the gears in the transmission. Yes, a Z06 has a different gearbox (M12 vs. M6). M12 (Z06) has shorter ratios in the lower gears.
Old Apr 19, 2005 | 02:18 AM
SJTrance's Avatar
Ah, I understand what you're saying.
Old Apr 19, 2005 | 02:20 AM
As stated above, the gearing is different in the transmission itself. The rear end gear ratio on a Z06 is however the same 3.42 as in every other stock C5 Manual transmission car.
Quote from Z06.Com
Originally Posted by z06.com
M12 6-Speed Manual
This transmission is unique to the Z06, and is the only transmission available for that model. It is not available on Corvette coupes or convertibles. It has more aggressive gearing to increase torque multiplication in most forward gears, allowing for more rapid acceleration and more usable torque at higher speeds. A transmission temperature sensor was added to protect the M12 from higher thermal stresses. The sensor warns the driver via the Driver Information Center with a TRANS OVER TEMP light if thermal loads become excessive, meaning that the transmission could be damaged if not allowed to cool down.
Gear Ratios
LS1/MM6 LS6/M12
1st Gear 2.66:1 2.97:1
2d Gear 1.78:1 2.07:1
3d Gear 1.30:1 1.43:1
4th Gear 1.00:1 1.00:1
5th Gear 0.74:1 0.84:1
6th Gear 0.50:1 0.56:1
Reverse 2.90:1 3.28:1
Old Apr 19, 2005 | 12:03 PM
oange ss's Avatar
Whoa! A contradictory statement. I'm tuned back in. Anyone like to respond? Better breathing must mean more power, right?
better distribution of crankcase pressure, reducing crankcase windage...power gains would be minimal and only at very high rpms
Old Apr 19, 2005 | 12:53 PM
TheBlurLS1's Avatar
That's what she said...
Originally Posted by oange ss
better breathing ,not oiling
better breathing inside the crankcase, not breathing into the engine (as in more fuel/air).
i consider this to be an oiling related subject, which is what i was referring to in my first post
but the main point is, you're not going to gain 25hp by having an ls6 block.
Old Apr 19, 2005 | 12:57 PM
TheBlurLS1's Avatar
and SJ, do you have a stall in your car? if so how big? a nice 3500+ and a 230+ duration cam (fm13, g5x3, trex etc.) tuned well, along with your boltons + LS6 intake, and some underdrive pulleys, you should be able to get out in front of a z06.
Old Apr 19, 2005 | 04:09 PM
oange ss's Avatar
has nothing to do with oiling...there's a difference between oil pressure and oil breather pressure
