Thinking about some heads
Old Apr 18, 2005 | 11:29 PM
9silverbird8's Avatar
Default Thinking about some heads
Just looking for opinions. Thinking again about going heads and cam. I've narrowed my choices to these two.
MTI stage 2E or TEA stage 2 both 5.7 LS1 castings.
Also, I've noticed A lot of guys seem to be running 5.3 castings. Whats the benefit in this?
Thanks to all
Old Apr 18, 2005 | 11:32 PM
TVWilkes's Avatar
The 5.3L heads will give you added compression.The PRC 5.3L heads raise the compression to 10.8 unmilled.
Old Apr 19, 2005 | 05:53 PM
Thats what I thought, do they flow much/ifany worse than a 5.7L casting?
Old Apr 19, 2005 | 08:35 PM
slow trap's Avatar
if you're stock cubes i'd get the tea stage 1.5 5.3s
Old Apr 19, 2005 | 08:58 PM
Why so? The stage 2 doesn't seem to flow too much more than the 1.5's.
Old Apr 19, 2005 | 09:19 PM
INVISIBLEZ's Avatar
Check my sig GMPP LS6 heads are unbeatable for the price. They make badass power. These heads don't just make the advertised peak number people like to brag about, it's the killer flow through out the 500's also.
Old Apr 19, 2005 | 09:30 PM
777's Avatar
777
what kind of prices are we looking at??
Old Apr 19, 2005 | 09:54 PM
Ya those do look pretty nice, a bit more pricey than either the MTI or TEA's at about $2k for the pair.I assume one would want to upgrade the springs though as they are the stock '02 ZO6 springs.
Old Apr 19, 2005 | 10:02 PM
INVISIBLEZ's Avatar
They were 1899.00, they make awesome power even with a small cam. My cam is 228/230 .591/.581 112 lsa. and I made 437/407 through a 12 bolt with 4:10 gears and 18X10.5" Z06 wheels.
Old Apr 19, 2005 | 10:22 PM
All else being stock? Do you think I would I be able to hope for close to the same numbers with an otherwise stock setup and a slightly more aggressive cam(no idea which yet, haven't even begun researching that)
Old Apr 19, 2005 | 10:29 PM
BriancWS6's Avatar
Good numbers........but I hope your not running the LS6 springs with that cam If so, Mr. Valves meet Mr. Piston
Old Apr 19, 2005 | 10:30 PM
INVISIBLEZ's Avatar
No sir, Comp 918's
Old Apr 19, 2005 | 11:30 PM
99blancoSS's Avatar
TEA stage 1.5 rev 2. Flow great and for a very reasonable price. I'm saving for them.
Old Apr 19, 2005 | 11:50 PM
That's what I was thinking, but for a few hundred more you can get new LS6 castings ported by LPE, which if I've seen correct numbers, outflow the TEA as well. Decisions, decisions.....
Old Apr 19, 2005 | 11:53 PM
TVWilkes's Avatar
The 5.3L castings flow better than 5.7L heads IMO.
Old Apr 20, 2005 | 11:06 AM
BriancWS6's Avatar
No sir, Comp 918's
Just checking.
Old Apr 20, 2005 | 11:37 AM
99blancoSS's Avatar
Arent the ls6 heads a larger bore? wont that effect my compression? I was told to stick to the same bore size. What the effect?
Old Apr 20, 2005 | 11:42 AM
tim99ws6's Avatar
Nope, I am also running the GMPP LS6 heads. They are an incredible head. I had them independently flowed on flowbench(no exhaust tube), and they flow every bit what they advertise. Remember, these are stock valves that are outperforming some big name heads where it counts the most....the mid lift numbers. Peak cfm is worth nothing more than bench racing. If you wanna go fast, it's all about the low/mid range numbers.
Old Apr 20, 2005 | 12:27 PM
kazfan30's Avatar
correct me if im wrong.....but dont Summitt racing have GMPP LS6 heads for about 1450.00......Cause that was what i was looking into getting????? After all the whole LS1 to LS6 conversion for 01-02 cars is like only 1799.00.........what gives with these 1800.00 to 1900.00 dollar heads???????????
Old Apr 20, 2005 | 01:43 PM
99blancoSS's Avatar
My car is a 99. Its a different bore size. I understand the head flows great but what about the fact that the combustion chamber is larger than my bore size. What is the effect there is the question?
