395 rwhp NA with factory manifolds, cats and catback!
wow great numbers that must be the highest dyno numbers with the stock manifolds period! My setup is similar except I have JBA shorties and no cats and an slp y pipe, but I only make 20 more rwhp which should be expected I guess. My cam is a 222/224 .581 114 xer lobe comp cam custom grind.
In the search for more quiet, emissions-legal power, what does everybody think about adding a 90mm LSX intake and TB? Do you think it would give me gains? Keep in mind I have AFR 205 heads and a .600 lift cam that revs easily to 6800 rpm.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
I think you would probibly pick up around 10-15 more rwhp with the 90/90 since your car makes power up to 6800. The 90/90 doesn't shine until above 5000 rpms. It must be the 230 exhaust duration that helps your car make power above 5800 with the stock exhaust as my car peaks at 5800 and starts to lose power pretty fast above 5800. By 6400 I am down 10 rwhp or maybe a little more. I wonder if a tune with ls1 edit would help make power above 5800 or or do you think nothing will help, since my cam is a 222/224 any thoughts?
have you thought about porting out the stock manifolds to get a few more ponies? I've read a few guys got 5-9 horses, and there is a company that ports them out and claims 10 rwhp. I myself living in California have very little choice but to run a small cam and port them out, can't wait to see what I can get out of them.
__________________
How would that cam do with MACs and True duals (Random cats, Magnaflow X, over axle into 2 (14" Magnaflow muffs)?
Would you say another 10>15 rwhp?
What is the TR reference name or # on that cam?
__________________
__________________
Very impressive numbers for the set up. Thunder Racing should deffinately market this package. Heads, Camshaft, Intake Manifold, Throttle Body, Lid, and a Tune.
I'm sure there are a ton of people in California that would love to make 400rwhp and not have to touch any of the smog equipment.
Hell, I'm out $200 every two years to smog my car and that's the friendly discount rate. God have mercy if I ever get pulled over.![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Thunder should call it "Beat the California Smog **** Package" and sell the crap out of them.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
__________________
#34
Originally Posted by tuffluck
that is definitely awesome. on a car with a lid and a cutout that dyno'd 323/335, what would you expect that cam to do?
__________________
#37
Originally Posted by UMD_Jesse
Have you touched your short block? i.e ARP rod bolts, etc?
__________________
#38
Originally Posted by Patrick G
I've considered trying the Extrude Hone process, but I'm not sure if the gains would be worth the expense. Does anybody know what it costs? BTW, check out the photo and see if you think there's any hidden power in these babies:
#39
its about time people started recognising the potential of smaller cams that match the comoponents of the entire car, not installing bad-*** 230+ cams to force power into a total package that works against it. Well done. And this is exactly he kind of stuff that will make big cam hi-stall drivers cry.
No idle issues
Emissions compliant
Cheaper by half
Smooth and responsive
More economical
Killer times at the track (close to 12.0 I believe)
No idle issues
Emissions compliant
Cheaper by half
More economical
#40
Originally Posted by Jeffs99SS
Very cool setup!!! I definately see that combo taking some money at the street races. You'd have everyone looking for a bottle for sure. ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
__________________
