AFRs *arent* the only game in town, it seems...
#41
i couldn't explain it to you if i tried, but you need to read J-Rod's thread on timing and such. VERY interesting read, if you can digest it all. it basically says every motor combo has an optimal timing point, and that more isn't necessarily good.
#42
Timing is just that, timing. Every engine has its "best" timing; and the lower the amount of timing for maximum power- the better the combustion chamber shape is in that head. The more efficient the chamber- the less timing it requires to properly fire the mixture to make maximum power. This doesnt mean that a cylinder head that requires more timing than another will not make more power than the other.
#43
1 Post
![Wink](https://ls1tech.com/forums/images/icons/icon12.gif)
The cure for timing your engine for maximum power...
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
http://www.msdignition.com/ignition_23_7531.htm
Ed
Ed
#44
6600 rpm clutch dump of death Administrator
Good fast burn chambers don't need timing. Older poorer design chambers need more timing to get he chamber charge burned in time...
Props on your heads Visceral.
I'm not being ugly here to TEA, Visceral, or anyone else, so PLEASE do not take it as such.
TEA's bench is not a Superflow 600 or a Superflow 1020. The 600 is what you see "most" shops use. We can all sit around and say that all benches should be the same, but the reality of the situation is even within the same mfg (say Superflow) there are variances between benches. When you move between mfgs. there are even greater variances in many cases.
TEA has pointed out their bench is certified by NIST, etc... My point of this is that the only real use of those numbers is from a delta standpoint. In other words the differnece from what they did stock to what they do now.
To compare TEAs numbers on thier bench to Tony's numbers on a Superflow 600 is an erroneous way to do a comparison. Flow numbers are simply one part of the overall performance of a motor.
I'll agree just with Andy. I've seen a set of heads that flowed better than another set of heads. But, once you bolted them on, the lower flowing heads made 30-40 MORE hp. I'm not saying this is always the case. What I'm saying is there is a lot more to good heads than just flow numbers.
I know I've harped on port volume, velocity, etc... I just want folks to understand that before you jump all over this post and only look at the raw data , you need to understand that there are more factors you aren't looking at that will skew the end numbers...
Let me cite a non-flowbench example. Look at going from a dynojet 248c to a Mustang, and then over to a Dyno Dynamics dyno. All three of them are rear wheel dynos. You take the same car and have all three dynos in the same shop and you will see a huge variance. Does the car loose HP, or is the way the dynos interpret the power input very? The answer is the dynos vary.
Go over to HPE if you doubt this. They have both, in the floor. We've dyno'd on on the dynojet ~470 RWHP, unstrapped a car, and moved over the Mustang and seen ~430RWHP. On a DD dyno the car would be ~390-400RWHP. Do you see where this might not be a fair comparison if you try to compare two different car?
Look, these heads may be the best thing since sliced bread, I'm not saying they aren't. My only point is if you want to compare numbers, put them on the same bench with the same operator. Then, take them to the track... Other than that the rest is just a lot of chest thumping.
#45
Originally Posted by jaberwaki
"Needs"?
you'll have to forgive me on this one(oldschool gear head here) when is being ABLE to run more timing a bad thing?
last time i checked being able to run more timing advance was a good thing...
things might have changed and i am always up for learning something new things. (another words i'm not bashing, just confused by this statement.)
if i can run more timing advance, then i should be building cyliner pressure faster, and as long as my heads can support that on the exhast side then i should be making more power.... is this totally off?![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
If you have a very efficient chamber you will not need to light the charge as soon as a head with a chamber that is less effcient. The better the mixture motion of the port and chamber, the less timing is required to make as much or more power. Don't forget that the piston is still on the way up the bore when the spark plug lights off. A "fast burn" chamber has a faster moving flame front and hence is more efficient.
Remember how on old school SBC engines everyone used to like to run 38* timing? BBC most guys ran 40* Pontiac guys 34-36. It was mostly due to a combustion chamber design. Todays engines do not need as much timing because the combustion chamber design is way more efficient.
#46
While we are on the subject of combustion chamber efficiency, I don't think ANYONE could argue that the AFR chamber design is not a superior piece than the "General" offered out of the factory. It's another often overlooked benefit the AFR cylinder head provides. The only way a factory ported casting could be as good is with welding and major surgery....a process that can compromise the ultimate integrity of the cylinder head if not done properly.
As far as trying to compare flow numbers, unless its on the same equipment with the same operator it becomes a completely invalid test. Ive seen a couple of posts that stated the AFR 205 exhaust ports were flowing over 265 CFM @ .600....(we advertise 230 CFM). Although flattering, the reality is you won't see those type of numbers on ANY SF600 or 1020 benchs. What does this all mean....It means if you TRULY wan't to compare flow numbers and actually learn something, it is essential it is done on the same piece of equipment, because much like dyno's, a flowbench is a useful tool but none of them across the country are calibrated the same. Then throw in all the other variables like bore diameter and height, clay and radiused entries, flow tubes, no tubes, and different shaped tubes (straight and curved), and the liklihood of significantly different results moves up exponentially.
Tony M.
Tony M.
#47
Originally Posted by BrentB@TEA
The head in question is not "hogged out" It comes in 6CC's larger than a Fully CNC Ported AFR225.
It is also not really a box stock head when you consider it is fully CNC Ported.
Look in the Sponsor sales section. I posted 205 numbers compared to our 5.3 stg1.5 rev2 port.
I thought the comparison was between this head and a AFR 205? Wouldn't that make the difference 26cc? That looks like a considerable size difference.
#48
There is no reason to compair the 205 with a set of stage 3 heads.
Big differences everywhere.
the compairison was between the 225's and the stage 3 6.0 heads from TEA.
The other compairision was between the 205's and a set of stage 1.5 5.3 heads.
#49
I could be wrong, but from what I have read TEA has flowed a set of 205's and 225's on their bench.
When they compair numbers it is between both heads on the same bench with the same setup.
If you looking completly at flow numbers then this is a good apples to apples comparision.
It still dosen't show which head will make more power.
I believe you are dealing with 2 of the top head companies on this board.
If someone said pick between a set of 225's and stage 3 heads for the exact same amount of money you would probally see me look like this.
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
#50
SN95 Director
Originally Posted by JZ'sTA
I could be wrong, but from what I have read TEA has flowed a set of 205's...
Originally Posted by Tony Mamo @ AFR
... Ive seen a couple of posts that stated the AFR 205 exhaust ports were flowing over 265 CFM @ .600....(we advertise 230 CFM). Although flattering, the reality is you won't see those type of numbers on ANY SF600 or 1020 benchs....
Tony M.
Tony M.
#51
Someone needs to Dyno their AFR 225 heads on a 408 and then change nothing and dyno a set of TEA's equivalent heads and see what happens. That would be more interesting to me, I could care less about flow numbers.
-Sly
-Sly
#54
2 bad none of us have that kind of money.
That would be damn near 5,000 dollars in heads, plus dyno time, plus tune time, plus labor.
Ouch.
Ouch.
FYI, I would be willing to do the test myself. All I need is a donor 408 and the 2 sets of heads. I will handle the rest.
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
Brandon
#55
Good fast burn chambers don't need timing. Older poorer design chambers need more timing to get the chamber charge burned in time...
To compare TEAs numbers on thier bench to Tony's numbers on a Superflow 600 is an erroneous way to do a comparison. Flow numbers are simply one part of the overall performance of a motor. .
I'll agree just with Andy. I've seen a set of heads that flowed better than another set of heads. But, once you bolted them on, the lower flowing heads made 30-40 MORE hp. I'm not saying this is always the case. What I'm saying is there is a lot more to good heads than just flow numbers..
I know I've harped on port volume, velocity, etc... I just want folks to understand that before you jump all over this post and only look at the raw data , you need to understand that there are more factors you aren't looking at that will skew the end numbers....
A dyno is not a flow bench. But I see its a good comparrison. one is an industry standard since it is cheap and readily available. It may not work as well as the other but its price point puts it in a lot of shops.
Good point I will post a comparrison of both on the same bench at the bottom of this post![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
[/QUOTE=J-Rod]Look, these heads may be the best thing since sliced bread, I'm not saying they aren't. My only point is if you want to compare numbers, put them on the same bench with the same operator. Then, take them to the track... Other than that the rest is just a lot of chest thumping.
Go over to HPE if you doubt this. They have both, in the floor. We've dyno'd on on the dynojet ~470 RWHP, unstrapped a car, and moved over the Mustang and seen ~430RWHP. On a DD dyno the car would be ~390-400RWHP. Do you see where this might not be a fair comparison if you try to compare two different car?.
No one from TEA is chest thumping. Same bench same bore,same set up
Below is some same bench comparisons. First up is an AFR 205 head comparred with our 1.5 head. Notice the intake side flows within 1% of what AFR says it will. Thats why we sell them!
Below is the average of the last 3 sets we have done with the new program test 2 is an AFR 205 as tested on our bench. All heads tested with clay radiused inlet,3.9 bore
___________________tea 1.5rev2_____________________afr205
_________________Average of last3__________only 1 test in database
.100________________69.36_________________________ __64.1
.200_______________139.97_________________________ _140
.300_______________202.4__________________________ _203.4
.400_______________251.4__________________________ _250.1
.500_______________289.86_________________________ _282.9
.550_______________303.9__________________________ _296.5
.600_______________315.83_________________________ _303.4
_________________TEA 6.0Stg3________________AFR225
.100______________72_______________________68.9
.200______________151.5____________________152.4
.300______________224______________________225.6
.400______________274______________________277.5
.500______________318______________________310.5
.550______________335______________________323.0
.600______________345.5____________________307.6
#56
-Sly
-Sly
#57
Tony M.
Tony M.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
#59
I'm glad to see you posted a side by side test of a TEA 5.3 right beside an AFR 205. That to me gives folks a good side by side comparison to see where your numbers come in at.
My point being is that most of the numbers out there have been derived from SF600 testing. Tony's numbers from AFR were derived from an SF600. So, when someone goes and compares those numbers to some other bench, made by a different mfg, I usually see differences. Even from a 600 to a 1020 you see differences, and those are benches from the same shop.
My point was if you are trying to compare numbers from inside of TEA's operation to numbers from outside its not a fair comparison hence my comment about "chest thumping". I think we've all seen folks take one set of flow numbers from over here at bench Y, and try to compare them to the numbers over bench Z and feel its a fair comparison.
With that said. I appreciate you taking the time to post comparative data derived on the same bench, same buret, same operator, and same orifice. That to me is hard data... The posts above that compared an AFR head, but it made not mention (that I saw) to orifice, 205 or 225, etc...
Let me cite an old post I made about 2 yrs ago
My point again about the chest thumping is benches are but one tool and they need to be understood as such. A delta of before and after performance, just like the track. Hence my comments.
In short, thanks again for the info, now, bolt those bad boy on and share some good news with us....
I'd also like to take a moment to make sure that I am not taking a jab at Visceral, or TEA. I'm not casting doubt on the numbers TEA generated. I fully believe if TEA said they flowed that number on their bench they flowed exactly that. I simply don't want folks to look at one point on a flow sheet any more than they look at one point ona cam (.050). Anyhow, I hope my comments were not mis-construed as casting TEA or these heads in a negative light. I just want folks to understand data in its context.
Here was a very interesting bit of info that I came across. Just like a dyno, even flowbench results can be skewed. I am not going to name the two heads that were tested, as I am not interested in get into a peeing match with shops about their heads or a he said, she said argument. This information is being posted as that, information. Use information like this to educate yourself, and make informed decisions. For the purpose of this test I will refer to the same vendors a Brand X and Brand Y.
In a test of Brand X heads vs Brand Y heads. Brand Y flows as well on the bench (as good as a Brand X), but don't seem to make the same power on the dyno,etc. From discussing it with the head porter, he was mentioning that Brand Y removes material in areas that will show a gain on the flow bench, but will not make anymore power on the dyno. He says they are big in the wrong spots and too small in others.
A set of Brand Y stage 2s 5.3l heads on a car that had all the bolt ons and a TR224 cam. It made 379/370 or so before adding the heads. After the heads, the car did 413/385 after tuning. A week before, Another car had a set of Brand X stage 2 5.3l heads on a car that already had the TR224 cam as well and the IDENTICAL mods as the other Brand Y car (FLPs, LS6 intake, ASP, stock rear/4:10s,etc). Both dynoed the exact same before swapping heads on (the curves practically overlayed one another). This car pulled 443/418 with the Brand Xs!
On the flow bench, the Brand Ys actually flowed better from .100-.550, while Brand X flowed slightly better past this. Same thing on the exhaust side. This just goes to show that a flow bench is an excellent tool, but not something that should be used as the determing factor in how a head will perform when put on a motor. The CC volumes were identical on the two heads, so compression difference wasn't an issue.
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
