The drama continues
Old May 5, 2005 | 07:51 PM
APEX ACE's Avatar
Default The drama continues
As some of you know I have a brand new LS6 in my 02 Z06 that blows the dip stick out. This afternoon I check to see what's inside the air-bridge and throttle body. More oil. How can the oil get in there? The PCV system is hooked up after the air-bridge.
Also, is it normal to have major air bubbles in the radiator over-flow?
Dave
Old May 5, 2005 | 08:49 PM
jlrz28's Avatar
10 Second Fun Car
Hows your oil pressure normal??
Old May 5, 2005 | 08:59 PM
rxracer's Avatar
sounds like you have "blow-by"
Old May 5, 2005 | 11:34 PM
APEX ACE's Avatar
The oil pressure is strong. It's a ported and shimmed pump. 30 at idle...over 50 going down the road.
Old May 5, 2005 | 11:35 PM
APEX ACE's Avatar
I'm taking the car in for a compression and leak down test tomorrow. I'll let you know what we find.
Old May 6, 2005 | 02:50 PM
CHRISPY's Avatar
Is it a stock short? Sounds like headgasket or piston/ringland problems.
Old May 6, 2005 | 07:23 PM
APEX ACE's Avatar
Update:
The compression test was great 125-130 psi on all 8 cylinders. Good news!
The leak-down has all 8 cylinders at 5%-8%. Good news!
The air bridge and throttle body still have oil in them. WTF?
The radiator over flow tank still looks like a jacuzzi tub on full blast. WTF?
NO smoke come out of the exhaust at all. Good news!
The car runs strong as hell. I've pounded on it yet... but you can tell!
It's a forged LS6 with a 227/231 591 113 cam and Stage 2X heads.
Any more ideas?
Dave
Old May 6, 2005 | 07:27 PM
1QuickT-A's Avatar
i say **** it... put ur foot thru the floorboard and let it eat!
Old May 6, 2005 | 07:47 PM
01ArcticSS's Avatar
Originally Posted by APEX ACE
Any more ideas?
Dave
I don't even know if this is possible to do, but is the PCV valve in backwards?
DISCLAIMER: I'm not a mechanic. Don't want to be a mechanic. I do like to fix my own car because I typically don't trust your average everyday dealer mechanic, unless I've been drinking with him - then he will never touch my car. When I do fix my car, I dig out at least THREE reliable sources on how to actually make the repair - I read them and keep them handy while I do the repair. So the above suggestion is based on little to no information. Sorry if I wasted your time. But I do wish you the best in solving your problem.
Old May 6, 2005 | 07:49 PM
smask04C5's Avatar
sounds like you are pressurizing cooling system, not good
Old May 6, 2005 | 08:44 PM
Spellbound's Avatar
AMW Catch Can? Don had the same problem........
Old May 6, 2005 | 09:02 PM
APEX ACE's Avatar
Hey Duane,
Next time you fire up your ZO6. Tell me if the radiator over flow tank looks like a jacuzzi? I was talking to Don and said he remembers that it did?
I took the catch can off and re-installed the stock PCV system to see if that made a difference? Maybe tomorrow I'll try the catch can again.
Dave
Old May 6, 2005 | 11:02 PM
Spellbound's Avatar
I fired it up and let run for awhile....no major bubbles, sorry. Hope you find out whats wrong.
Old May 7, 2005 | 07:26 PM
Spellbound's Avatar
Hmmmm,
https://ls1tech.com/forums/generation-iii-internal-engine/317890-cometics-leaking.html ???
