Crank Bolt
Old May 10, 2005 | 06:13 AM
NVE THIS's Avatar
Default Crank Bolt
Where can I get a longer than stock crank pully bolt? I'm swaping cams and would like to have the longer one. Can this be picked up from a retail shop around town, is there anything special about the bolt? I got a replacement one from FMS with my gasket kit, but I think it's the stock one. Thanks.
Old May 10, 2005 | 06:42 AM
Stark's Avatar
Yep, the one you got from FMS is your STOCK replacement bolt.
I went to Napa and ordered part #2801-225. It's a 16mm x 2.0 pitch x 120mm long bolt. I also ordered part#8071-0358, washers get 2 or 3. You'll need to use the washers on the longer crank bolt when you reinstall your crank pulley.
Hope this helps, and good luck with your cam swap.
Old May 10, 2005 | 07:03 AM
bowtieman81's Avatar
I got mine from a Cat dealership, same size as the one listed above. I would bet a decent hardware store would have some as well.
Old May 10, 2005 | 08:25 AM
foff667's Avatar
LS1TECH Sponsor
i got mine from http://www.mcmaster.com/
Old May 10, 2005 | 08:41 AM
240M3SRT's Avatar
Is it absolutely necessary to remove the crank pulley when doing a cam and why?
Old May 10, 2005 | 08:43 AM
ttyson's Avatar
um
to get to the cam?
www.installuniversity.com
Old May 10, 2005 | 09:03 AM
240M3SRT's Avatar
I never really took a good look but i didnt know if the cam could come out as it sets up above the crank some distance but maybe the timing chain cover interferes.
Ive never done one so i dont know.
Old May 10, 2005 | 09:04 AM
foff667's Avatar
LS1TECH Sponsor
yes its necessary...you cant put the timing cover without it off and the cam is behind the timing cover
Old May 10, 2005 | 09:06 AM
777's Avatar
777
unless you have the qtp timing cover...which is quite a bit of money
Old May 10, 2005 | 09:09 AM
240M3SRT's Avatar
I thought it might be possible to slide the timing cover behind the pulley if it were designed that way. I didnt realize the cam was completely unexposed behind the cover this is my first v8 and a pushrod motor at that.
I guess im stupid so lets all roll our eyes...i really appreciate it
Old May 10, 2005 | 09:10 AM
foff667's Avatar
LS1TECH Sponsor
www.ls1howto.com lol
Old May 10, 2005 | 11:29 AM
Grimes's Avatar
Your question was not stupid. I don't know why ppl use the rolleyes so often.
Old May 10, 2005 | 12:28 PM
Racer8102's Avatar
I got my longer bolt from a hardware place called Fastenal, bolt was like 6 bucks and shipping was about the same, I got it the next day. Hardware stores around here didn't carry that size bolt and napa wanted me to order 5 of them to make the order.
