Cam Question
Old May 11, 2005 | 07:16 AM
JG853's Avatar
Default Cam Question
Hello everyone:
I am new to this site and have a Z06. As it relates to changing the cam in the Z06, what do you guys think about installing a 229/242 631/631 114 LSA?
What are the pros / cons to this cam? (I already have Long Tubes, Random Tec Cats, and a Corsa Titanium Exhaust. I will put Comp 921 Dual Springs, Push Rods, Retainers, Seat and Seals on as well).
Or should I go with a GSX-2 112 LSA cam?
Thank you for your expertise.
Old May 11, 2005 | 08:15 AM
777's Avatar
777
the first cam is huge and you won't be able to run it without major flycutting...and why such a large split? i wouldn't go much past .600 lift unless you plan on flycutting the pistons...what are the specs on the gsx-2 cam...
since it seems you are wanting a large cam, i would go with a custom grind from futral, or the f-14 (232"/234" .598"/.598" 112LSA)...the f-14 would prolly make 425rwhp on your stock ls6 heads
Old May 11, 2005 | 09:37 AM
JG853's Avatar
This is the GT-1 cam from a very respected tuner on this site (I will keep names out of it). No fly cutting necessary as the 921 springs allow for up to 650 lift.
GSX-2 specs are 224/228 595/608 112 LSA
What do you think?
Old May 11, 2005 | 09:42 AM
777's Avatar
777
just because the springs are rated to .650 lift, doesn't mean it will be ok with the piston to valve clearance...i can assure you that a cam with .631 lift will not clear the pistons unless you have flycut pistons...is the GT-1 not a lingenfelter cam? i believe you would be fine with the gsx-2...however it does seem a little odd that the lift is that high on that small of a duration
Old May 11, 2005 | 10:16 AM
GuitsBoy's Avatar
Yes as said, the springs are not the limiting factor. Its like putting z-rated tires on your yugo and saying it will hit 149 MPH.
That cam would be a monster in a motor with stock cubes. I wouldnt even think about something like that. The cam only record holders dont even run cams that big. I also suggest looking at the f-14 or even f-15 is you want something bigger. If you want something radical, check out the t-rex, but these are all much smaller than what you listed above.
Old May 11, 2005 | 10:18 AM
lilbuddy1587's Avatar
i say check out lgmotorsports.com ----> vendor, they have some wicked cams that make great power and arent nearly as big as the cam u mentioned.
Old May 11, 2005 | 11:51 AM
JG853's Avatar
That is correct
Old May 11, 2005 | 12:00 PM
JG853's Avatar
That is correct
Old May 11, 2005 | 12:08 PM
PREDATOR-Z's Avatar
G5x2 is
G5-X2-112 G5X2 232/240 Duration & 595/608 Lift at 112 Lobe Seperation.
G5-X2-114 G5X2 232/240 Duration & 595/608 Lift at 114 Lobe Seperation.
Both fit on stock unmilled heads.
Old May 11, 2005 | 12:16 PM
wes96z's Avatar
Try the x2 cam from lg it make great power and you wont have to fly cut your pistons the specs are on lg's website
Old May 11, 2005 | 12:44 PM
PREDATOR-Z's Avatar
The specs are 2 posts up
