LS6 intake & FAST intake
Old May 19, 2005 | 02:29 AM
c0ncEpT's Avatar
Default LS6 intake & FAST intake
What would be better for a 99' TA A4 an LS6 intake or a FAST intake?
Old May 19, 2005 | 02:53 AM
Scoobie's Avatar
What are your long term goals? budget?
Old May 19, 2005 | 04:47 AM
XTrooper's Avatar
The LS6 intake manifold would be better for your wallet!
Seriously, unless you are going FI or with a larger displacement motor, I don't believe the difference in performance provided by the LSX intake manifold is worth the almost doubled expense, but that's just me.
Old May 19, 2005 | 10:39 AM
badpewter-z's Avatar
LS1TECH Sponsor
depends on your setup really
bolt-on to mild cam only or H/C ls6 would be fine
mid-wild H/C id go with the fast 90/90 so not to starve the motor of air on the top end
FI - either would work fine as it doesnt have to pull air through its pushed through
with the smaller setups its up to you if the 5-10hp is worth the extra cash for the fast setup
Old May 19, 2005 | 11:38 AM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
On my Head/Cam, stock cube setup, the 90/90 really woke things up.
If you're not touching the internals, the LS6 is plenty fine.
Old May 19, 2005 | 11:43 AM
Visceral's Avatar
You put a Fast 90/90 on a Saab???
Old May 19, 2005 | 11:49 AM
bigdsz's Avatar
The guy that recently notched my pistons told me he dyoed a stock cube heavily modded LS1 and the FAST 90/90 only picked up 3RWHP over the LS6 intake. He did say that a big cube engine would definitely benefit.
Old May 19, 2005 | 12:02 PM
Wicked_Hugger99's Avatar
ive been contemplating this too. Think im gonna stick w/ the LS6/ stock ported tb till i get heads, forged bottom, and run a bigger shot o giggle juice & then add the 90/90. Which TB is better though, the fast 90 or Nicks 90tb?
Old May 19, 2005 | 12:09 PM
!LS1 11 Second Club
Old May 19, 2005 | 12:10 PM
!LS1 11 Second Club
NW or TPIS. Stay away from the FAST TB unless ALL of their issues have been fixed.
Old May 19, 2005 | 12:51 PM
Derek98z's Avatar
I just installed a 78 FAST intake and TB on a friends car. Replaced the LS6. It is a mild cam and most bolt ons in an A4 car. His the SOP difference was minimal. He has not dyno'd it since though.
Old May 19, 2005 | 12:55 PM
!LS1 11 Second Club
78mm LSX not worth the swap over an LS6 intake.
By Brett Foote | 2026-06-04 05:00:17
