Fuel Filter Change
Old May 19, 2005 | 03:38 PM
mustgofasster's Avatar
Default Fuel Filter Change
Is Changing The Fuel Filter Fairly Easy? The Biggest Job I've Ever Done Is An Ls6 Intake Swap. And That Was A Pain But It Was Easy. I Dont Even Know Where The Filter Is At. Please Help!
Old May 19, 2005 | 03:53 PM
GreekGator's Avatar
installuniversity.com go there. They have a whole right up on how to change it.
Old May 19, 2005 | 04:32 PM
GuitsBoy's Avatar
Easy but messy. Cover your eyes, and if possibly your mouth. I learned the hard way.
Old May 19, 2005 | 10:55 PM
SidewayzOZ's Avatar
That write up is a good one, and yes definitely cover your eyes and mouth I found out the hard way too
Old May 19, 2005 | 11:07 PM
00Vette's Avatar
How often do you need to change the fuel filter. I bought my car with 40,000 miles on it, it has 70K know and I've never changed the fuel filter......
Old May 20, 2005 | 07:29 AM
minivette's Avatar
I'd say change it.
Old May 20, 2005 | 08:06 AM
GuitsBoy's Avatar
Every 30K is recommended. You can probbaly get away with changing it later though. Careful though as a clogged dirty filter could limit fuel flow at high rpm making your car run lean and ping, but this is a worst case scenario, youll likely never clog a filter to this point unless you picked up a tank of few of filthy gas.
Old May 20, 2005 | 08:09 AM
NHRATA01's Avatar
I just do it every time I change the plugs which is about 10k miles. Its cheap, and it doesn't take long to do - except the one time I had a bitch of a time getting the flare nut to thread back into the filter for some odd reason.
Its a bit mess, have alot of rags ready, do it in a well ventilated place, and wear gloves - the gas will burn your hands if you are in prolonged contact with it.
Old May 20, 2005 | 09:33 PM
Sudz's Avatar
i just did this like 2 weeks ago, when you take your old filter off the gas would not stop coming out of the line from the tank to the filter, so i quickly put the new filter on that line and it stopped it from coming out then i just slid it into the bracket and screwed it back on
Old May 20, 2005 | 09:36 PM
ss rally red's Avatar
I change mine every 15K,its so cheap and easy to do and you never know when you get a tank of gas with some bottle of the barrel sediment in it!
