MTI or AFR heads?
www.non-sponsor.com
My Vette made 412rwhp with a cam-only and no UD pulley and the stock TB.
Mike
that was with stock head gaskets, a baby TR224, and before the cutout and ported TB.
Given the same runner volume, NOTHING I have seen come across my bench (or other peoples bench I trust to be accurate) has matched either AFR in flow (205 & 225). And only a select few have exceeded some of the peak #'s the AFR's routinely put down out of the box, however the disparity in port volume was tremendous and almost always the low and midlift #'s were softer.
The AFR's are extremely optimized for their size....I think an average "hand porter" has a greater chance of hurting them then helping them. A tremendous amount of R&D went into the port design and CNC execution of these cylinder heads. A talented ported could get them to flow more, but at higher lifts with an increase in port volume and larger cross sections....and a high likelihood that the end results would hurt some of the low and midlift numbers. Don't forget that the same talented hand porter would then have to duplicate his masterpiece seven more times on both intake and exhaust....not easily done if the port truly flows kick ***....any slight change in contour, shape etc. will quickly have a negative effect on a port thats close to optimal.
And yes....the proof is in the results....there are loads of positive AFR results and experiences in the Dyno section almost every week.
Also, comparing 7, 8, and 9 second race vehicles to the cars that typically run our "production style" bolt on AFR's is a bit silly....apples and oranges to say the least. We are manufacturing a killer "bolt on" street head for the masses, still capable of making big power and holding its own at the strip with right choice of complimenting components.
Tony M.
Given the same runner volume, NOTHING I have seen come across my bench (or other peoples bench I trust to be accurate) has matched either AFR in flow (205 & 225). And only a select few have exceeded some of the peak #'s the AFR's routinely put down out of the box, however the disparity in port volume was trememndous and almost always the low and midlift #'s were softer.
Tony M.
stop posting and get the small chamber 225's ready j/k....
I am waiting to see some, "worked," AFR's produce some great track numbers. Not saying that they will or won't, but at the end of the day, proof is in reality.
I believe you have a good product and I reliese that it has to appeal to certain market group. I think it would be silly as well to compare base AFR's to worked (10-30 hour) heads and not state that. Not my intention at all. I would like to see results from worked AFR's. Reality now, on a, "great and well worked," big bore head, intake flow at .600 is running 345-400 cfm, exhaust 230-270.
The nature of things, is that these numbers will look mild in a couple of years as things evolve. EG. Corvette three valve head or Ferrari 430 five valve head(remember that motor is only 3.5 liters)
