Possible Problem
Old Jun 3, 2005 | 09:37 AM
KAOS's Avatar
Default Possible Problem
not really sure if this is an issue to bring up or not. i have my heads back on and tightened down, using arp studs. well i got looking and the studs on the drivers side are flush or just barley protruding from the nut. and on the drivers side all the studs stick through about an 1/8 of and inch, if that. i thought that i made sure all studs were down as far as they could go when i put them in. this is the second time this has happened any body else have this issue
Old Jun 3, 2005 | 10:42 AM
KAOS's Avatar
n e body
Old Jun 3, 2005 | 10:50 AM
HAMRHEAD's Avatar
Did you make sure the bolt holes in the block were cleaned out and free of any fluids? This could keep them from going all the way in and cause your block to crack.
Old Jun 3, 2005 | 04:52 PM
KAOS's Avatar
yeah i thought so i used an air compressor and hosed everything out really good. has nobody ever had this happen? the big studs look ok its just the small ones on the top row and only on the passengerside. they are consistant all the way across. this is conserning me. if i just took the small studs out would i have to get new gaskets? i mean i dont know what to do. any help would be great
Old Jun 3, 2005 | 04:59 PM
Scalpel's Avatar
Can you get a picture of what you're referring to?
Are the studs/nuts in question actively compressing the cylinder head down? I.E. are the nuts on the studs mating with the head at all?
Old Jun 3, 2005 | 05:00 PM
KAOS's Avatar
yeah let me get a pic or two and i will send them to you. you got pm, but just ignore it
Old Jun 3, 2005 | 05:44 PM
KAOS's Avatar
cannibal, feel free to post those pics when you get them
Old Jun 3, 2005 | 06:22 PM
crainholio's Avatar
I'm thinking you meant to say "passenger side" for one of these...
Old Jun 3, 2005 | 08:30 PM
KAOS's Avatar
yeah sorry, on the passenger side they are flush on the drivers side they are protruding slightly, both sides are symetrical for what is going on. just hard to believe that it would be like on all of them.
Old Jun 3, 2005 | 09:05 PM
KAOS's Avatar
pics
Old Jun 3, 2005 | 09:22 PM
Brains's Avatar
You need to chase the threads in the block before threading in the studs. This happened on an iron block we got back fresh from the machine shop. They were a little "stiff" going in, so we pulled them back out, chased the threads, put a small amount of lube on the studs and they threaded in with fingers and all lined up fine.
Old Jun 3, 2005 | 10:04 PM
KAOS's Avatar
so would i have to take the heads back off? and why would this be like this on just one side? all of the passenger side are flush. so that means that they are fine, correct?
Old Jun 4, 2005 | 12:35 AM
Ed Blown Vert's Avatar
Blowing them out isn't enough. I blew mine out. Then used a shop vac. Stuff still came out. Then took a grinded down bolt and re-threaded it. And more junk came out.
Old Jun 4, 2005 | 02:55 PM
KAOS's Avatar
new question are the heads on the ends thicker? each stud in the center row is just barely through the nut but just on the ends and on each head. the exact same amount of stud is sticking out above each nut. is this common or just another problem with not cleaning them out enough
