Max Flycut depth for factory LS1 piston
Old Jun 13, 2005 | 03:31 PM
Phil99vette's Avatar
7 Second Club
Default Max Flycut depth for factory LS1 piston
Whats the max depth you can flycut an LS1 piston?
.050
.070
.100
I thought someone told me .100 but just want to make sure.
Phil
Old Jun 13, 2005 | 03:35 PM
gomer's Avatar
Some of mine are at .100 and have been like that for a while without a problem.
Old Jun 13, 2005 | 04:31 PM
Jason99T/A's Avatar
I can shift faster than you.
I have been a good bit over .100" on both the intake/exhaust on "personal" motors with no problems. I just would just keep it strictly n/a at that point. lol
Jason
Old Jun 13, 2005 | 04:37 PM
PREDATOR-Z's Avatar
Just flycut for the amount needed. Too much and you loose SCR, not to mention it makes it weaker.
Old Jun 13, 2005 | 05:07 PM
bigdsz's Avatar
I don't know how you guys get such exact cuts, I ended up somewhere around .057-.070. It was really tough to be accurate on my car.
Old Jun 13, 2005 | 07:38 PM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
We've cut 170
Old Jun 13, 2005 | 07:44 PM
Jason99T/A's Avatar
Originally Posted by -Joseph-
We've cut 170
That's where mine were.
Old Jun 13, 2005 | 08:54 PM
gomer's Avatar
We've cut 170
Holy ****.. I don't feel so bad about my .100 now
Old Jun 13, 2005 | 10:41 PM
7 Second Club
Ok, sounds good. Is there any accurate way to measure how deep the flycuts are?
Phil
Old Jun 13, 2005 | 10:42 PM
7 Second Club
Anyone have a pic of a finished piston?
Old Jun 13, 2005 | 11:05 PM
bigdsz's Avatar
You can use the valve drop method,where you set the pistons at TDC, and measure using a dial indicator. before and after dropping the valve on to the top of the piston. You can use a feeler gauge and your finger nail to feel when the notch has the correct feeler gauge in it. Also you can measure the width of the eyebrow with a digital micrometer once you have established the depth you want on at least one flycut.Lastly you can put the end of a digital micrometer in the notch for measurment.
Old Jun 14, 2005 | 03:07 AM
Jason99T/A's Avatar
I attached some that were 0.170" intake/0.130" exhaust.
The piston still needs to be deburred and polished before final assembly. I'll snap some pics of those tomorrow.
Jason
Attached Thumbnails Max Flycut depth for factory LS1 piston-dsc01515re.jpg   Max Flycut depth for factory LS1 piston-dsc01516re.jpg
