PRC or AFR heads
Tony, I think AFR heads are about the best out there, but that's not a fair comparison. We have dynos of the PRC heads and they pick up close to the same amount of HP and nearly as much torque as the AFR 205s. Plus, they are based on the GM casting, which we all know is utterly inferior. How else would LS1s with over 150k miles still be running perfectly fine? <-- Sarcasm.
Phil, if you aren't going to spray huge amounts of nitrous on your engine or run loads of boost, the PRCs will be fine, especially for the price. Hell, for the amount of money saved, you could buy a nitrous kit to go with the PRCs and spray a 150 shot (which won't destroy stock heads because of their inferior deck thickness) and you will wipe the floor with the AFR headed car you would have had.
But, if you have the money, then this isn't an issue. Buy the AFRs because it is a better head, and you'll pay for it. If it is, then the PRCs and nitrous is a better value.
what you buy is what you get with the AFR's. to me consistancy is worth an extra weeks paycheck. and in the grand scheme of things when your all said and done a h/c setup will run you ~3k, whats a few more dollars spend toward the better heads...
The statements about consistancy is completely rediculous! All PRC cylinder heads are checked & triple check & I believe are every bit as consitant as the AFR heads. Just because something is alot more expensive doesn't always make it better. Maybe it means they just have alot of overhead...
The bottom line is both heads are really nice & will offer great power gains!
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
compression can be made up my milling and thinner gasket, the heads can be bought bare for the springs and valves of your choice, or you can upgrade the springs to the 8019's (i believe) which have seat and open pressure comperable if not more then the platinum springs. even so, the standard associated golds have already proven to be a great spring and more then what is needed for most cams out there.
like i said in my PM, i'll have a chance too see some independent numbers on a new set of PRC's, im interested too see how they fair.
and for the record my heads where "advertised" TWICE to flow more then a set of AFR's, to bad independent testing didnt share the porters same enthusiam....
Y'all gotta tell me about that deal JRP!
Ed
As more and more results roll in from customers, I think we'll see the scare tactics fall to the side.
If anyone has any questions or concerns about any of the PRC cylinder heads, feel free to give me a call or shoot me an e-mail at trevor@texas-speed.com.
Trevor
Trevor
434 rwhp @ 6000
413 rwtq @ 4500 approx cant remember
made over 400rwhp from 4700-7000
PRC 2.5's, Futral FM-8 N2O cam 225/233 .59/.59 114, all major bolt-on's.
I am very pleased with my decision. And too the guy asking about nitrous on either heads. I made 648rwhp 700rwtq from a 225 shot. This was on the stock short block.
Now back on topic.
It was a pleasure talking to Tony at AFR and Jason at TSP today. Both enlightened me not only about heads, but how my car will react to a little TR224 which at one time was a big cam
Both of you answered an array of questions about more than just heads on the car, but additional parts I thought ID need but wont need.
like I said in the first thread, leaving 10 RWHP on the table isnt a factor for me. ID be happy with 410 RWHP, and I think Id make it with AFR and be close with PRC.
I wont be putting juice in the car so that is off the table.
Id like for the car to be able to be driven on a hot florida day w/o pinging on 92 oct
I just have to see if personally Id like to buy heads and a clutch for the same price I can buy a slightly better head
The bitterness of poor quality remains long after the sweetness of the low price is forgotten!
Ed
Get the PRC's and put the extra money towards the clutch....I'm sure they will work fine. Seems you are not as concerned with some of the unique features and structural benefits the AFR's offer as you are with saving the money. I'm not even kidding....the AFR's are a good head but no product is the right choice for everybody.
Plus I think if this goes on much longer I might have a nervous breakdown
(Just having some fun....
Seems we could use a little "levity" on this board of late...) Anyway, it looks to me like a no lose situation....either direction you...uuum....choose....has it's merits and would would work out well
Tony M.
