what to do?
Old Jun 23, 2005 | 09:10 PM
DamanSS's Avatar
Default what to do?
I have a 2000 SS M6, and i have been looking into a procharger for quite a while, but recently i have wondered what cam/heads would do for my car. I was wondering what kind of performance can i expect with doing cam/heads/headers/off road ypipe? And, about how much would it run for me to do that? I know that it will suck to take the motor out since i heard you have to take it out from the bottom of the car, or is that necessary to do these mods? Thanks!
Old Jun 23, 2005 | 09:21 PM
Keenov's Avatar
Taking the motor out is not necessary. The gains you will get and the power you will make is dependent on the heads/cam choice. Most heads/cam combos range from 400rwhp - 510rwhp. It is dependent on the setup.
A decent set of heads can set you back $1500 - $3000. A cam could range from $200 - $500 depending on which one you go with or if you get it used.
You are also going to need a decent clutch and a 12 bolt to support these mods.
