lash question
Old Jun 26, 2005 | 06:56 PM
pdd's Avatar
pdd
Default lash question
my lash is set at 3/4 turn past zero lash. should i put a spacer under the rockers to bring the lash to a 1/4 turn past zero lash? with my 7.350 PR and .024 mill with .045 head gaskets i came up with .031 closer to cam per the pushrod calculator
https://ls1tech.com/forums/showthrea...rod+calculator
so if take 7.400 - .031= 7.369
so with 7.350 PR i was gonna add a .014 shim under the rockers. what do ya think?
also my zo6 85mm MAF was butted against my varam , not fully attached during my dyno. i dont know if that would affect my dyno or not.
Old Jun 26, 2005 | 11:11 PM
slowpoke96z28's Avatar
with the way its set up now, where is the rocker touching the valve throughout one revolution of the cam?
Old Jun 27, 2005 | 11:57 AM
pdd's Avatar
pdd
i havnt checked it yet, but was thinkning if i had less preload it might free up some HP
Old Jun 27, 2005 | 12:43 PM
P Mack's Avatar
Use shims to get rocker geometry right, use pushrod length to get preload right. If you know how much less preload you want, you know how much shorter pushrods you want too. Measuring is better than math in this case.
