Shortblocks...Which one?
I shoot 100 from the line and 100 activated 200rpm before peak trq.
5177 NOS kit has 2 solinoids that run in series. What I did (learned from KOOLRAYZ, another member) is run these noids independently each capable of a 125 shot.
You run the main line into a Y, from the Y each line into a noid and from the noid into your air box.
My first line is activated by original kit switch in ashtray, my second via a rpm activation switch. Both switches are relayed through the WOT switch, so at end of run, releasing the throttle deactivates both of them.
They are also relayed into an FPSS at the fuel rail (safety measure in case fuel pressure fails)
My tranny is an FLP stage 4 built to handle 600rwhp comfortably so I shoot through the gears.
Dry is more sensitive to tuning than wet, this is where I believe that people tend to be shy, because it requires more tuning knowledge and monitoring.
The nice thing is you can't kill the motor by overreving since if you hit the limiter, fuel pressure drops and FPSS deactivates.
IMO it is a very, very safe system.
WOT switch is primary arming and other switches are secondary.
As for tuning you tune for NA and 100 shot is handled without any mods if you run higher octane gas.
For the second stage the timing box regulates the on/off and retards the motor by 3*. The enrichment is done via MAF Translator after 3000 rpm.
That is all I need since since I run 98 Octane pump fuel over here.
http://www.thunderracing.com/catalog...vid=3&pcid=203
MAFT is an easy way to modify your NA AFR tune for on/off track
I run Stoich AFR at 14.7 and WOT at 12.4 (N20), 13 (NA)
Timing at WOT on N2O is 25* NA is 28.5*
Of course that is relative to my setup and yours will have to be tuned live.
From personal experience backing 1* is sufficient up to 150 shot with 93+ octane.
Our chambers are very efficient.
Basicaly you have to monitor on live system and retard untill you do not have KR, if you do then you back 1 more and so on.
Otherwise just taking the rule of thumb, you are leaving power on the table.
