need help identifying a camshaft
Old Jul 1, 2005 | 11:36 PM
Mighty Wings's Avatar
Default need help identifying a camshaft
on the camshaft itself, it reads: lunati spf-1 t5qa 112 230385(S) or it could be 230305(S) Anyone know the specs?
Old Jul 2, 2005 | 08:59 AM
Josh-'98 Z28's Avatar
I would drop an email or call to Lunati themselves. That way you get exact info...
Old Jul 2, 2005 | 09:52 AM
PREDATOR-Z's Avatar
I looked at Lunati site and they only advertise 55001LUN>55009LUN as cams.
Perhaps this is a custom grind by them
Old Jul 2, 2005 | 12:19 PM
mellowyellow's Avatar
Thats the slower than Brian cam LOL.
Old Jul 2, 2005 | 07:52 PM
Thanks for all the info guys, I called lunati, but they can't identify it either. It's a custom cam.
Slower than Brian cam? we'll see soon enough..........
Old Jul 2, 2005 | 10:51 PM
If that's the case, your only choice is to contact someone with a machine that can read the lobes. I think its called a Cam Doctor? I know Lingenfelter's shop has one. For $39 or so they'll "read" your cam and tell you what the specs are.
Old Jul 3, 2005 | 07:17 AM
Thanks, I might have to do that. I know that you can use a micrometer to read the lift and that you can use a degree wheel to read the duration, but the latter seems complicated.
Old Jul 3, 2005 | 11:28 PM
Steve - Race Eng's Avatar
LS1TECH Sponsor
Default Cam Doctor
I've got a high definition Cam Doctor here if you can't find someone locally. I also have specialized software to process the Cam Doctor data providing durations at various lift points of both lifter and valve, as well as quality of grind using various high def graphs.
Steve
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Old Jul 3, 2005 | 11:35 PM
2xLS1's Avatar
Steve
What do you charge for that service?
Old Jul 4, 2005 | 12:27 AM
LS1TECH Sponsor
Default Camshaft analysis
The charge depends on how much detail you are looking for. I can process one intake and one exhaust lobe to give you the duration at .050" and the lobe spread for twenty bucks. More detail, processing the above data through my high end software runs fifty bucks. With that you will get durations at .006", .020", .050", .100", .200", and .300" lifts at both lifter and valve. It is also possible to check all the lobes and get a printout of the deviations of durations, lifts, lobe spreads for the entire cam.
The Cam Doctor is a very valuable tool for checking the quality of grind as well as the durations. My high end software (very necessary) plots base circle run out, acceleration curves, jerks, etc. What looks like a good cam is often found to be defective in either manufacture or design. You can't grind a good cam on a worn out machine or on a machine with an out of balance grinding wheel!
Steve
__________________
Steve Demirjian
Oceanside, Ca.
760-630-0450
Old Jul 4, 2005 | 09:47 PM
Steve
Thank you, I might have to send it to you if I can't get the specs locally. I did find out that the cam might have been sold at AMS in Arlington. Are they still in business?
Old Jul 5, 2005 | 01:38 PM
no they went down almost two years ago.
Old Jul 5, 2005 | 03:10 PM
Really? My luck. I got the specs finally. Thanks everyone.
