how can i tell the difference between LS6 and LS1 intakes?
Originally Posted by Y2K SS
The only way I know how to tell the diff is from underneath. The LS6 is flat underneath. Im sure the part number on the side of it will tell also.
"- The only way to tell 100% if you are buying an ls6 intake, especially used is to ask for pics of the bottom. The vette LS1 intake does not have an EGR provision so its easy to pass that off as an LS6 if you are none the wiser. The difference between the LS1 and LS6 intakes can be see here; the ls1 intake is on the left and the ls6 is on the right."
from jrp's mod guide
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
looks like i got an LS6 intake. thanks guys. as always, you came through for me![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
i will be putting on the heads and cam in next week and will post my results.
going in: LS6 intake, asp pulley, MTI stageII heads milled .03, MTI stealthII cam, LS2 timing chain, new oil pump with o rings.
Ive been searching and searching through the forums trying to find what parts I need to install this manifold. Can someone who has bought and installed everything and that knows whats right please post up the part numbers so that theres no confusion?
not meaning to highjack the thread, just wanted to get this straightened out for everyone. Thanks
*Note: Must order GM Part#: 12578838 (Coolant pipe) & 2 - 12563325 (Coolant plugs) to re-route coolant passages for LS6 intake. These are listed for $28.36 on gmpartsdirect.com.
However, SDPC states: "You will need a new air bleed pipe (12568478) and 2 plugs (12563325) to convert a '97-'00 LS1 to the new LS6 intake."
p.s. i have already done the coolant bypass on the vette.
