HELP!!!Double Roller Clearance Issues!!!
Old Jul 13, 2005 | 09:55 PM
M6WS6's Avatar
Default HELP!!!Double Roller Clearance Issues!!!
I am at the moment installing my Rollmaster Double roller (10:00 Wed night). I have the shims in place for the oil pump and it clears the chain fine. I went to put on the cover and the oil pump hits inside of the front cover! Anyone else with this problem?How did you go about fixing it?
Old Jul 13, 2005 | 10:00 PM
Bluehawk27's Avatar
what kind of pulley are you using? the old ASP pullies had this issue and needed to be machined to fit.
Old Jul 13, 2005 | 10:06 PM
NVR4GET's Avatar
you have to machine your front cover for the pump because of the shims. It is a must for a double roller timing chain
Matt
Old Jul 13, 2005 | 10:08 PM
Bluehawk27's Avatar
I dont think so, i didnt have to machine anything, especially not my front cover.
Old Jul 13, 2005 | 10:28 PM
M6WS6's Avatar
havent used a pulley yet, just trying to get the front pan to fit over the oil pump, so you have had the problem before?
Old Jul 13, 2005 | 11:09 PM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
Did you have the timing cover gasket in place?
Old Jul 13, 2005 | 11:31 PM
Bluehawk27's Avatar
it should fit fine then, unless like joseph stated the gasket wasnt on. Sometimes it's the simplest things.
Old Jul 14, 2005 | 08:08 AM
777's Avatar
777
^ I didn't have any problems with my double roller.
Old Jul 14, 2005 | 08:14 AM
SideStep's Avatar
I was getting ready to order one of these from TSP.... Keep us posted...
Old Jul 14, 2005 | 09:21 AM
rufretic's Avatar
No problems when I installed mine. I don't think you should have to machine it.
Old Jul 14, 2005 | 10:19 AM
eallanboggs's Avatar
You do NOT have to machine the inside of the front cover. The cover is paper thin and couldn't handle being machined anyway. You need to check your work. Of course you didn't leave the cover gasket off because you bought a new one when you got your cam and installed the new gasket along with a new " O " ring, right? Did you install the shims properly? The one that goes on the output side of the pump MUST be oriented correctly. What about the pickup tube going into the pump with its' "O" ring. Did you get that one properly? Did you torque all the bolts down evenly? Did you check that the pump is square and flush against the block. Last but not least are you SURE the cam chain/ Oil pump drive sprocket is FLUSH against the BOSS on the crankshaft?
Old Jul 14, 2005 | 10:22 AM
777's Avatar
777
I have pulled the cover three times and never used a new gasket. The gasket looks perfectly fine and I have NO leaking. My only suggestion is to make SURE the cam chain and sprocket are flush against the boss on the crankshaft.
Old Jul 14, 2005 | 10:52 AM
1BadMoFo's Avatar
I second that, make sure it's flush, should fit just fine if you bought the right one.
Old Jul 14, 2005 | 08:02 PM
M6WS6's Avatar
Everything is in I believe correct. I transfered everything from my motor to the new one and have everything torqued to specs in the Christopher Endres Book. I have a new front main seal, that was NOT in place. We were test fitting the double roller. This is a new oil pump also. The shims are in the correct place, and we used sealant on the one shim where oil passes through which was stated in one of my directions. Just one spot of the driver side and the oil pickup flange are the only things touching. The oil pickup is not a probelm, that can be ground down becaues that side isnt even used for the pickup(the pickup only has one bolt). My dad and I have double and triple checked everything. This is by far NOT the first motor we have put togehter, just the first LS1.
Old Jul 14, 2005 | 08:08 PM
M6WS6's Avatar
Rollmaster
Old Jul 14, 2005 | 08:11 PM
M6WS6's Avatar
I didnt get a new cover gasket, Speed Inc said since they were o-ring type, it wasnt needed to be changed, plus, a new one was installed 10000 miles ago.
Old Jul 14, 2005 | 08:14 PM
M6WS6's Avatar
I have a feeling others have had this problem but never noticed it. It is hardly noticeable, but I wanna get it right. I have a feeling that many people when installing inside their engine bay did not recongize the problem and torqued it down. One thing I find interesting is the depth of the threads to the bolts, seems like the bolts bottem out really early when nothing is under it, just a interesting note.
Old Jul 14, 2005 | 08:40 PM
xssive's Avatar
Mine had this issue. I had to clearance the area around the crank seal about a 1" outside
