Oil consumption/burning
It is definitely down on power, but its running through a VERY restrictive exhaust, and want to go thru it and see what issues it may have. It pings a bit at low (3000) and right before peak torque RPM (4300) no matter what timing and air fuel (all the way down to 18 degrees and 11.8:1)
That makes me think its definitely consuming oil and detonating. Need to figure if its a systemwide deal (just some .028 thou ring gaps
and needs a 250 shot to seal it up) or a couple cylinders are loose. PCV line looks to be dry no oil, so Im thinking rings or valveguides are way looseStock 6.0 heads, mid 240s duration cam, shorty headers, 370+ inches. Is there some way o measure blowby with some sort of accuracy? besides a leak down anything else you guys can think of to check? It was running a oil commonly recommended on here, but was thinking of switching to Valvoline racing or something with a bit more viscosity to see if it would keep it from pushing the oil
I like the idea of putting some longtubes on it and hitting it with the 250 shot myself
) if it was abused by a previous owner, we dont have any way of knowing. It could just be ringed super loose but no one knows
