Stock ls1 heads...worth porting?
Old Jul 19, 2005 | 07:00 PM
willis 00's Avatar
Default Stock ls1 heads...worth porting?
i just got my tsp 233\239, full valvetrain,4000 stall and some other mods installed.i have a guy that does all my labor, he does really good work. he has the ability to port my factory heads. i havent seen much on people doing this to stock ls1 heads. how much is to be gained? is it really worth getting ls6 or 5.3 heads? anything i should know or ask for?
Old Jul 19, 2005 | 07:08 PM
777's Avatar
777
Depending on cost I would say yes/no.
Old Jul 19, 2005 | 10:30 PM
ls1wannabe's Avatar
dont get ls6 heads the difference betwwen porting the ls6 and ls1 arent much if you get 5.3 heads expect probably 15-20 more rwhp/rwt
Old Jul 20, 2005 | 08:59 PM
AKRA's Avatar
It depends on who is doing the porting. Most of the after market heads require a core charge which means they are just re-doing your heads for the next person. If done correctly, you could see 20 to 25 hp with stock valves.
Good luck,
Al
Old Jul 20, 2005 | 09:00 PM
willis 00's Avatar
15-20 rwhp over ported ls6-ls1 heads w/ 5.3s? i heard these heads worked good with my cam but, i didnt think it was that much.
Old Jul 20, 2005 | 09:05 PM
AKRA's Avatar
It's more like 5 hp plus the 25 to 30 youe normally gain with LS1 Stage two heads. But the extra compression will hurt you if you ever deside to go with a turbo, supercharger or nitrous.
Good luck,
Al
Old Jul 21, 2005 | 07:06 AM
PREDATOR-Z's Avatar
Good luck,
Al
The extra compression can never harm nitrous. The higher the better (assuming all supporting parameters are upgraded)
Old Jul 21, 2005 | 04:58 PM
willis 00's Avatar
i think iam going to go ahead and let him port the stockers. all i need is new gaskets right? i can use the stock studs with out any problems cant i? is there anything i should ask for? iam going to keep the factory valves.
