***Introducing our Vacuum Pump ***
Old Jul 24, 2005 | 06:25 PM
C_Williams's Avatar
Originally Posted by Cody Brooks
14-15 lbs will give you all the ring seal you need. for that much money it should be electric so that you can hide it say where the a.i.r. pump used to be and not have to mess with your accessory belt.
14"-15" of vacuum, at sufficient CFM, would need 1.0 HP- 1.5 HP DC motor and that would require well over 60 amps, not to mention the weight. Not practical.
Old Jul 24, 2005 | 06:43 PM
TAQuickness's Avatar
How hard would it be to fit this unit into the F-Bod AC location?
Old Jul 24, 2005 | 07:34 PM
LS1Quickeee's Avatar
What kind of torque gains would you see? The price seems step hopefully it will come down in price after being out for a while.
Old Jul 24, 2005 | 10:26 PM
Cody Brooks's Avatar
didn't figure It'd take that much electric motor well anyways. I think I'd wait for a cheaper option and a better mounting location. near the ac would be a great spot. I think I'd also want a small serpentine like that on the ac for the sake of a serpentine being a better design and not having to re-tension the belt every time I tear down the front of the motor for something.
Old Jul 24, 2005 | 11:18 PM
C_Williams's Avatar
When the next F-Body is in the shop I will see what alterations are needed.
Thanks,
Charlie
Old Jul 24, 2005 | 11:27 PM
C_Williams's Avatar
Cody, this does mount above the AC on the C5 and looks like it will be a drop-in in the F-Bodies as well.
Also, in this application, a cog belt design is superior to that of the serpentine belt because vacuum pumps can not take side loads. Besides, I don't think a serp is made that short.
Thanks,
Charlie
Old Jul 25, 2005 | 01:00 AM
Mike94ZLT1's Avatar
I made a WOT switch and bracket, and used my air pump for the exact same thing. Cost me about $30.
Old Jul 25, 2005 | 05:50 AM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
JMX did some testing of an electric vaccum pump. At low speed it was able to pull vaccum. Under load it was unable to pull vaccum on the engine and saw no net benefit. This is a great idea, and a great addition to the LS1.
Old Jul 25, 2005 | 06:41 AM
santiago's Avatar
Originally Posted by 69firebird
you have to remember this is designed for vettes, tey can afford that kind of stuff
not all of us bro lol
Old Jul 25, 2005 | 09:28 AM
GrannySShifting's Avatar
Originally Posted by KingCrapBox
I wonder who will be the first to set the relief valve to 30" on there street car.
Wristpns dont need any oil do they?
Old Jul 25, 2005 | 10:22 AM
1fastWS6's Avatar
13"-15" is the max. recommended vacuum for any wet sump oiling system due to issues such as what GrannySShifting just mentioned. 30" shouldn't be a problem with a dry sump system such as on the new C6.
I for one don't think the price is out of line at all. If you've ever shopped for a vacuum pump you'll find you can't touch just the pump for less than $350. After you piece together all the fittings, pulley's, belt, etc. your up to $800 EASY. I know...I just installed one on my race car.
Old Jul 25, 2005 | 11:40 AM
  #32
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Originally Posted by shouldaboughttheZ
Really nice piece. But $800 for 12rwhp?
Nice stuff guys!
shouldaboughttheZ, go ahead and make say 750rwhp, and now try to make 800rwhp. Not that easy.
Old Jul 25, 2005 | 12:09 PM
  #33
v8maro's Avatar
The price is kinda steep, I know if it were around 500-600 I'd be in for sure. What really bugs me is the kit doesn't include everything you need, you still need a catch-can :lame:
-Steve
Old Jul 25, 2005 | 12:25 PM
  #34
LOnSLO's Avatar
At 30" of vacuum, your valve covers will suck in.
Old Jul 25, 2005 | 01:24 PM
  #35
1fastWS6's Avatar
Exactly....everything is exponentially more expensive the faster you go. If you can't afford $800 on a vacuum pump, chances are you don't need one either. I don't know about the pump advertised here, but most pumps are not meant for street/daily driving anyway because they need to be rebuilt often.
Old Jul 25, 2005 | 05:37 PM
  #36
C_Williams's Avatar
This can be used as a daily driver. I logged over 10k miles with the prototype and the pump remained as effective after 10k as the day it was installed.
That being said, my bet is that most people who buy a vacuum pump are high horsepower, limited annual mileage motors and of those, most will be large inch or ultra high revving stock stokes.
Charlie
Old Jul 25, 2005 | 07:48 PM
  #37
V8_DSM_V8again's Avatar
While I am ? on the price I am a firm believer in the vaccum pump...
I will probably have a moroso on it..
Esp when you build an engine with having one in mind.. LOW TENSION ring pack saves friction and seals better with a vaccum pump..
The combination of the low tension rings and 15" can be good for over 50hp in some cases.. Most of the time with regular rings 20hp... On forced induction engines more so towards 50hp...
Old Jul 26, 2005 | 09:28 AM
  #38
C_Williams's Avatar
Our pumps are competitively priced. We include all the mounting plates, bolts and hardware required to make this a 1 hour bolt-on.
Last, our pumps are the most compact and lightest vacuum pumps on the market.
Charlie
Old Jul 26, 2005 | 09:48 AM
  #39
Ben R's Avatar
$800 is a good price for a vacuum pump kit.
Old Jul 26, 2005 | 09:53 AM
  #40
J-Rod's Avatar
I look forward to testing one of these out in the not so distant future to see where it can take us... This is a fantastic idea, and implementation. We've been looking at how to do apump, and up till now it was goingt o cost us an accessory which wasn't an option. This idea is simple, elegant, and functional.
Props to you guys for coming up with this...
