1.85 rockers
guess my point was you can do a cam for not much more and get much bigger gains.
i much rather have a cam to where i dont have to fly cut the pistons so the rockers could stay on. my case the lift would of been well over 600 if i kept the rockers.
and i completely agree with your point. can't debate that at all. i only have a beef with those that stick to the go with a bigger cam mentality. not everyone wants to go through the motions and hassles of having a larger cam in their motor. some may want stock idle characteristics with a nice overall gain. after all, i put heads on the wife's car with a stock cam. idles and drives just like stock, but have 35 more rwhp. and on the stock PCM tune to boot.
PERSONALLY, i would just rather get a bigger cam( which i did). it comes out cheaper.
im not argueing with you. im just throwing out a different option.
i wasted my money getting rockers. i got a 10 h.p gain.
i dumped the rockers for a cam and gained 40 h.p.
thats not living in the past.
That's why we all use SAE corrected numbers. No, they aren't perfect, but trying to discount someone's gains using the weather is weak in my book.2. Roller rockers, like most things in life, are NOT all created equal. I swapped out a set of SLP 1.85 rockers for a set of Crane 1.80 roller rockers, lost ~.010" of valve lift in the process because of the slightly smaller ratio, and still gained 10 rwhp and 8 rwtq over the SLP's.
3. The idea that you can't use a high-lift cam with high-ratio rocker arms is a NON-ISSUE. The fact is, what would be a "low-lift" cam using the stock 1.7 ratio rockers becomes a "high-lift" cam with 1.80 rockers. Can't find a cam that will give you the exact valve lift you're looking for? Not a problem! You simply have a custom grind cam made to suit your needs and pay not a single penny more for it than you would an off-the-shelf cam. I'm on my third custom grind cam (2 Comps and 1 Cam Motion), all ground to work with higher-ratio rocker arms.
Advantages of Higher Rocker Arm Ratios
Since the introduction of our “Quick-Lift” rocker arm geometry, many pundits have debated the benefits of using higher ratio rockers as a means of increasing valve lift. Most of these debates have taken place on Internet websites where “everyone is an expert,” but there is no way to validate their credentials. Some of these people seem to think it is “unnatural” to use a rocker ratio higher than stock. They argue that if you want more lift, design it into the cam lobe. This argument has some merit to it as long as you have a big enough cam basecircle to begin with. However, on some special “stroker” grinds with small basecircles; increasing valve lift with a lobe change is not practical, as the basecircle gets so small that the strength of the camshaft (as well as resistance to torsional twist) is compromised.
Increasing rocker ratio as a means of increasing valve lift has several advantages; not the least of which is that it is unnecessary to remove the camshaft in order to reap the advantages of increased lift. Of even more importance, however, is the fact that when the lobe is changed to increase valve lift, everything else in the valve train changes in terns of acceleration and velocity (this includes lifters, pushrods, and the valve/valvespring assembly). This increases the operating stresses (due to the inertia of the mass of the components) imposed on the valvespring. Achieving increased lift by changing the rocker ratio does not change the acceleration and velocity of two very heavy components; the lifter and the pushrod. They continue to operate under the same conditions as the lower lift provided by lower ratio rockers. Only the valve/valvespring assembly increases in acceleration and velocity. This means that the valve spring has much less work to do controlling the valvetrain. Additionally, the extra leverage afforded by the increased rocker ratio allows the use of lower seat pressures to control the lifter as it returns to the basecircle and to control hydraulic pump-up of the lifter’s inner plunger. These advantages are significant and evident in the dyno testing we have done.
Certainly, you must be careful anytime valve lift is increased. Factors such as piston-to-valve clearance, retainer-to-seal clearance, spring seat and open pressures, and spring coil bind must be considered; but these are all issues that must be checked no matter how valve lift is increased. All of our testing at Crane has shown that increasing valve lift by changing rocker ratio (especially with any of our “Quick-Lift” rocker arms) is a very convenient and reliable way to increase the power level of an engine without changing the RPM band in which the power is made. For additional information on our “Quick-Lift” rocker arm geometry, please check our website at www.cranecams.com.
I have to admit I fell into that trap once, I bought JBA headers. $600 for a couple of horsepower. They were well made and pleasing to the eye they just didn't work worth a damn.
I really hate to see young guys, most of which don't have a lot of spare money being sold a panacea of what these rockers will do when most likely it is little or nothing. Let them spend their limited funds on something that will do them some good.
above way is more expensive than just getting a bigger cam that will pump out the same numbers as above set up. as i stated before im just throwning out a different option.
and truthfully, its the more common option.
you keep saying the rockers don't work and are a waste of money. yet, you can't substantiate that claim. there have been countless others that have used them with just about the same success. even chevy high performance did the test in a 5.3L no less and still made the power.
is the only support you have is why don't the 9 second cars use them? maybe because they didn't design their motor to use them. or how about this, the class restrictions do not allow the use of aftermarket rockers. some classes even say you cannot use more than stock lift. come on, you can do better.
now for those producing 450+ rwhp how about tony mamo's car? go over to corvette forums and look up neptune bill ( wild bill faries) documented over 500 rwhp on both vinci's and, your favorite, norris' dyno. now, both of these cars are using 1.7 ratio. but they are the crane rockers.
you do not see any of us telling the people wanting to do a cam before heads wasting their money, do you? the right way is to do everything else and leave the cam for last.
and let them spend their money on what they want to. if they want rockers, then by all means let them spend the money. instead of telling them it's a waste, how about being productive and say something like this:
while the rockers will produce a nice gain in overall power for about the same amount of money, or less, you can do a cam instead. but, if you are looking to get the most you can out of your motor, then use both.
i like that statement. because hell, i can counter your buy a cam because it's cheaper by saying buy a nitrous kit. there's no way you will ever get 150+ rwhp out of a cam for $600.00
Should have the leakdown test done tomorrow.
P.S.- If you're looking for an example of a car running in the 11's, amigo, just give me another month and a half till we get some cooler weather and I should be there!
well, technically we don't need to wait as i have the wife's car that runs 11s and does produce about 450 rwhp. but didn't want to bring it up as he would only say it's because i use nitrous. i'm sure he's refering to NA cars. so, in that case, we'll wait for your results.
buying rockers and a small cam will cost more than keeping stock rockers with a bigger cam. weather somebody installs it for you or not, you still need to buy rocker arms.
im not saying they(rocker arms) are usless, but they arent the cheapest way to go if youre gonna cam a car.
comp cams 220/224 .581/.581 115 LSA with vinci/crane 1.7 accelerated lift rockers vs vinci 055 cam 216/224 .551/.551 (1.7) 113 LSA with vinci/crane 1.8 accelerated lift rockers (brings lift to .589/.589) it made more overall power throughout the entire rpm range. and with smaller duration on the intake side to boot.
I am also thinking about the Magic Stick cam. Is there an variety of lifts, duration on this cam or is there just one stick available? What would be the gains in installing the cam with the rockers?
