Valley pan
Old Jan 13, 2003 | 10:33 PM
I follow no 1's Avatar
Default Valley pan
Do I need to replace the vally pan when I rebuild the engine?I see them forsale just wondering why.
<img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
<small>[ January 15, 2003, 11:01 AM: Message edited by: Pro Stock John ]</small>
Old Jan 14, 2003 | 12:01 AM
Constrictor 98TA's Avatar
Default Re: Valley pan
If you have the LS1 valley cover and have an oil consumption problem, or just want to upgrade your PCV system to the LS6 version, then yes, you will need to replace your valley cover with the LS6 version.
The LS1 PCV system sucks in air (and also some oil) from the valve covers. The LS6 system sucks it in from inside the valley which eliminates alot of oil in your intake.
Whether you decide to do it, its up to you.
Old Jan 14, 2003 | 09:18 PM
So all I have to do is replace the cover or are there more parts than just the cover?
