How the F did my engine blow?
Spun bearing on the number 7 cylinder. My father and I came to the conclusion that it wasn't oil starvation, but probably the fact the engine couldn't handle the high revs.
Anyways, any suggestions on a good forged kit?
Cannibal's advice is good, you could also run a set of Scat H beams in there too.
I'd replace the cam bearings while you are in there aswell.
Have the crank polished, or pick up a nice used one for cheap..
edit: these rotating assemblies can raise my cubic inches? Do I need a new engine block to go with these kits?
Another question is that if I wanna go with a higer cubic inch rotating assemblie, do I need to get a new engine block, or is the stock one fine?
sorry for such noob questions, when it comes to serious engine stuff, I am a bit lost.
You could always sell your stock block and go 400+ on a new Iron or ls2 block.
You wont gain any power for the mostpart with a forged crank/rods, but it will hold alot more power.
With the 383 you'll want to ad a set of heads, or (even with a cam large enough for the cubic inches) you'll run out of air flow around 6400rpm. I'd bet it would peak aronud 6-6200...
EDIT: Heres a shopping list I came up with from Thunder Racing, let me know if this is all I would need, am I missing anything?
Comp Cams OE Replacement Hydraulic Roller Lifters, SB Chevy & LS1 $219.99
Thunder Racing Heat Treated Chrome-Moly Pushrods, 7.400" (Stock length LS1) $109.99
Federal Mogul LS1 Main Bearing Set, Competition Series Super Duty Alloy, 3/4 Groove (STD) $69.99
Diamond Pistons LS1 Forged Flat Top Piston set w/ -2cc Valve Reliefs, 4.060" BORE / 3.622" Stroke / 6.098" Rods / 1.340" Comp Height / .945 x 2.500 Wrist Pins Included $469.99
Thunder Racing Billet LS1 Main Caps $419.99
ARP LS1/LS2 Main Stud Kit $167.99
Eagle LS1 forged crankshaft with 3.622" Stroke $795.00
ARP High-Performance LS1 "Cracked Rod" Connecting Rod Bolts $73.49
Lunati Pro-Mod Connecting Rods, LS1 Engine, 6.125" ROD LENGTH, .927 WRIST PIN, 2.100 CRANK PIN, .940 JRNL WIDTH $749.99
Order Total: $3076.42
What are you doing for a block? Dont forget the machine shop costs.
Do you really need billet main caps? Probably not.
Dont forget rod bearings and cam bearings too.
If youre going to keep the stock 3.622 stroke, just keep a stock crank. Nobody breaks the stock crank and why spend money if youre not going to see any advantage.
pistons are too big, you need rings too.
It would probably be cheaper to get a shortblock from a sponsor, where all the parts, machine work, assembly, etc is done.
I recommend getting an assembled shortblock - in the long run, it is cheaper and more reliable than working with local machine shops that don't know LS1's. And no offense, but unless your father has a machine shop and is experienced with LS1's, you should at least leave the machine work and rotating assembly installation to a reputable builder that specializes in LS1's.
Just my opinion, but it comes from lots of money spent and bad experiences.
My recommendation would be to buy the short block. Put your heads on it and install it yourself.
Good luck.
Did you guys ever figure out what was the cause of your engine going in the first place? I know you said that it wasnt oil starvation, but how can you be so sure. A spun bearing is invariably an oil starvation problem, no? Usually an engine that just cant handle the revs breaks a rod bolt and throws a rod out the side of the block. Just curious if it was ever determined which it was...
