How difficult is to Advanced a Cam
Old Aug 3, 2005 | 08:07 AM
FiveSevenEagle's Avatar
Originally Posted by TOZ
Well Cmotorsport sold me a cam that needs to be degreed. I didn`t ask for this. Should I return it or degree it ?
I spoke to Comp and they said I have to advance my cam 4 degrees. It is really a pain in the *** for what i`ve read, so hopefully someone here can guide me and make it simpler for me.
cam should be degreed ?? is it a MUST or just better to be degreed to gain max power from the grind ,
114 LSA and a 4 degrees advance then u have 110 ICL ... i`d say dot to dot thats it .. tho it is better to degree it to have the optimum hp and tq .
Old Aug 3, 2005 | 10:35 PM
TOZ's Avatar
TOZ
I got the engine apart need some feedback with the advance in the cam. I got the Adjustable timing set. Do i need still need the dial wheel ???
Old Aug 4, 2005 | 01:02 AM
jrp's Avatar
jrp
SN95 Director
check the cam guide.
Old Aug 4, 2005 | 07:36 AM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
Wow JRP, that's a very comprehensive thread (first time actually I've sat and read through all of it)!
https://ls1tech.com/forums/generation-iii-internal-engine/327734-cam-guide.html
Old Aug 4, 2005 | 08:30 AM
PREDATOR-Z's Avatar
It is not necessary to advance this cam. What happens with a +0 advance (straight up) is that your cam will peak a little later and go higher in rpms.
I have a 224/220 on a 116+0 and the motor loves it.
You can always offset the higher rpms by running shorter gears in the diff.
Also I was looking at your graph with cam and you shooting N2O.
Is your tune a nitrous tune?? I see the AFR is kinda lean even on the motor tuned section. It looks like it goes 13.5 in the early rpms. You can also notice that by the % gains that you are guetting. Kinda inneficient (even if it is dry)
Before you play with the cam i would get a right tune first.
Old Aug 4, 2005 | 08:36 AM
TOZ's Avatar
TOZ
I already had it Tuned. And couldn`t do anything about the lost on the low mid range. When I sent this spects to Comp they said I need to advance the cam to make it a truly 220/224 114, he said when the cams are custom grinde you have to do that. Rev extreme tuned the car, I don`t know if you are familiar with them, but they are good tunning. Oh, the car was tuned for motor.
Still need to know if I can do this only with the adjustable timing set or do I need to do dial as well.
Old Aug 4, 2005 | 09:17 AM
!LS1 11 Second Club
The adj. timing set should do the trick (without a dial). That's what it's for. Call SLP for any further questions.
Old Aug 4, 2005 | 10:26 AM
TOZ's Avatar
TOZ
Cool I will call SLP and Comp just to make sure.
Old Aug 4, 2005 | 01:54 PM
TOZ's Avatar
TOZ
ttttt
Old Aug 4, 2005 | 02:42 PM
PREDATOR-Z's Avatar
A set of 4.10:1 in the rear and you do not have to touch that cam, that I promise.
Old Aug 4, 2005 | 03:18 PM
TOZ's Avatar
TOZ
I`m not doing that, I just want to have the Cam advanced for now.
Old Aug 5, 2005 | 02:15 AM
  #32
TOZ's Avatar
TOZ
Quick question on the installation of the timing chain. The sprocket has the degrees on it.
I took the stock crank sprocket at 0 degrees, now to put the SLP one do I need to put it with the 4+ degrees facing the top and matching the cam sprocket dot. Or put it in at 0 degrees and then turn it to 4+ to make the actual advanced ???
Please Help.
