View Poll Results: AFR or TEA
Spend the extra money on the better head
97
68.31%
Save a bit of money and put it toward another mod or tuning
45
31.69%
Voters: 142. You may not vote on this poll
AFR vs TEA
#101
So can anyone answer....how would the GMPP LS6 heads compare?
With the GMPP LS6 heads' 61cc chamber, pistons out roughly .007, and a GM head gasket of .054"....static compression is 11.2:1.
With my intake valve closing angle of 40°, the effected compression is at 8.7:1....unless I've made an error somewhere along the way...
Is this too much?
Is this too much?
#102
Is this too much?
Is this too much?
#106
How do you figure?
I've done it twice and get 11.2 with the .054 gaskets and 11.0 with the .060 gaskets.
#110
Originally Posted by PREDATOR-Z
#112
Originally Posted by Beast96Z
FWIW, this calculator is the same as the one on ross pistons website. The piston height section will not read past zero deck. Notice it says, "enter .0001 for zero deck", it will not go past this for "out of the hole readings". When you enter .007" for your piston height, your actually telling it your piston is .007 in the hole. You have to enter a negative number if the piston sticks up past the deck, which this calculator will not read. When I figure it into this one: http://www.rbracing-rsr.com/compstaticcalc.html , I get 11.09 for his compression using the numbers he stated at the top of this page. I'd reccomend saving this calculator because it is LS1 friendly, whearas you have been getting false readings from the others.
No wonder I always under estimate. ****, I never paid attention to that.
One blind ****.
Thanks for pointing that out Beast.
Man, that means with my PRC's I'll be 10.97:1 (I like that)
#113
#114
I have had good results with both TEA and AFR
On my WS6...467, mods in sig...
My GF's car with TEA 5.3's, 430 locked, 410 unlocked with a 224/228 114 cam.
My ZO is a hybrid, AFR castings ported by TEA. 473/446< summer tune lol. Last winter it dynoed 488 Same dyno.
#116
Super Hulk Smash
Is this too much?
Is this too much?
With .060" gasket it is 10.55853614:1 and 61cc chambers.
Actual formula is: Compression Ratio = Cylinder vol. + clearance vol. + piston Comp. vol. + gasket vol. + chamber vol. divided by Clearance vol. + piston vol. + gasket vol. + chamber vol.
#117
Originally Posted by JakeFusion
Static Compression will be 10.71232231:1 with .054" gasket and 61cc chambers.
http://www.c5frc.com/calculators/Com...Calculator.htm
But with this one it is different (putting a negative figure for out of hole)
Which one is right???
#118
Actual formula is: Compression Ratio = Cylinder vol. + clearance vol. + piston vol. + gasket vol. + chamber vol. divided by Clearance vol. + piston vol. + gasket vol. + chamber vol.
Yup, just remember to subtract the clearence volume since the pistons come out fo the hole. And piston volume here is zero so that can just be omitted.
I'll be going with the 02+ GM MLS gaskets. Unless you guys see any reason to go with something else??? (PTV clearance and compression an issue)
#119
I still get 11.07:1 with 60cc chambers and .060" gaskets....
Cyl vol= 43.2595 cid
Chamber vol= 3.661425 cid
Clearance vol (piston out)= -.0835356 cid
.060 Head Gasket Vol= .7160194 cid
So,
Swept vol= 43.2595 + 3.661425 - .0835356 + .7160194 = 47.553409 cid
Unswept vol= 3.661425 - .0835356 + .7160194 = 4.293909 cid
Swept/Unswept= 11.07..............11.07:1 SCR
Anyone back me up on this?
So,
#120
Now I'm confused. That is what I got with the calculator I used.
As far as these numbers are concerned, aren't the heads supposed to be 61cc and the gaskets .064"? With the 3.898x3.622 with a -.008 piston height, .060" gaskets, and 60cc chambers, I get 11.09.
