forged 346 going to heaven & i'm in hell
however this wont help you till you get the machine work properly in the first place
good luck Trending Topics
good luckThe Best V8 Stories One Small Block at Time
the ring land is broken-why i had know idea at first-i am a mechanic not an engine builder -i really wanted to get a professional to check out my engine block -so i drove to Kentucky to see Brad at ForceFed -Sunday afternoon i met Brad at his shop- the general diagnois -looks bad- Tuesday he called me with the bad news- my engine is trash-on top of the cylinder being messed up -my ls1 block was not machine correctly -if i understand it right the top and bottom were tighter than the center -which caused the rings to flutter -massive blow by- and i wanted a little bit over 11 to 1 compression -my machine shop called Texas Speed for the milling specs 30ths -Brad told me that head was milled 50ths -my machine shop totally screwed up-i have only 2000 miles on the forged engine
NOW I HAVE NOTHING -i called the machine shop -he is a hard headed guy-he told me he machine everything correctly & that i blew it up -that i detinated -if this is true it would be because he milled the heads incorrectly which would take me over 12 to 1 compression-i don't know what to do now - any suggestions????? here are some photos...[img=http://img6.imageshack.us/img6/8641/p10101769vy.jpg]
[img=http://img6.imageshack.us/img6/5011/p10101818tm.jpg] Not trying to be a dick, but damn it man.
That sucks hard. I'd be having a documented secondary shop's oppinion/diagnosis w/a certified letter of demand hand delivered/signed for to the shop that built that abortion.
If he isn't readily willing to nut up..... get an attorney..... yesterday.
Good luck bud-
