Advice needed.Just installed oil pump.
Old Aug 9, 2005 | 08:10 AM
777's Avatar
777
Originally Posted by slt200mph
Good for you man...better to change that 75 cent part that could fail and ruin a engine..
You mean that $5 part right? I don't know where you are getting your o-rings.
Old Aug 9, 2005 | 08:20 AM
slt200mph's Avatar
I work at a Chevy dealer...check sig dude.. ..actually the last one that I got was free.. ..parts mgr. just gave it to me...
Old Aug 9, 2005 | 08:22 AM
XtrmLS1spd's Avatar
Great choice of changing the o-ring. When I did my h/c swap, I just reused my old one. Well, guess what happened? I had oil seeping from it and going all underneath my car. It was even seated correctly. Needless to say, I pulled it all back off and replaced it with a new one, and it did the trick.
Old Sep 29, 2005 | 03:50 AM
98A4LS1's Avatar
So, how do you determine which oil pump O-ring is the correct one if there are 2 available? What is the difference between the two? I have a stock GM LS6 oil pump ready to go on '98 LS1. I'm confused after reading a couple of threads on this subject.
Thanks
Old Sep 29, 2005 | 04:24 AM
LS1FIRE's Avatar
Thanks
I used the newer one without any problems on my 98.
