oily intake runners
Old Aug 13, 2005 | 09:12 AM
HavATampa's Avatar
You are correct and you told him this already. The thing is, his oily intake runners are before the head ports, not after. Unsealed rocker arm bolt holes will leak oil in the combustion and not generally get sucked back up in the intake ports. That does seem like a lot of oil for a catch can to handle. How long did you run it with the line from the valve cover plugged and why did you plug it up to begin with?
Originally Posted by 1ORANGEWS6
I was told that oil and air could leak through the threads of the rocker arm bolts if you have ported heads. I was told this by a friend of mine that is a mechanic that has built lots of engines and several LS1s.
Old Aug 13, 2005 | 09:35 AM
SSPerformance's Avatar
maybe 30min at most, i did the test for crank case presure and it dident make any presure nor did it make vacume
Old Aug 13, 2005 | 03:02 PM
the motor has very little time on it whoul dthis cause a compression test to be low say 150psi in the 1 , 3 , 5 , 7 cyls. but it does hold the 150psi and dosent drop off.
Is it possible the the guy ported the heads may have hit an oil passage and thats whats causing the oil in the intake
Old Aug 13, 2005 | 03:48 PM
Bill's 02 Z-28 SS's Avatar
Hi Folks
There is a vacuum in the intake so I don’t think oil in the head would get inside the intake unless it is under pressure. You would suck it into the cylinder and burn it. One way to make sure you are not suck oil thru the PCV hose is to disconnect it and plug it going into the intake. See if the smoking is cut down. How much oil are you losing?
Bill
Old Aug 13, 2005 | 03:50 PM
car has a total os about 30mins in the motor and has burn about a 1/2 qt
i have also unhooked the pcv and let it hang down and plud the intake so i dident make a vacume leak. i put 100psi to the #3 cyl and put a vac.psi gauge on the dip stick and it hold the 100psi and dosent effect the gauge at all
Old Aug 14, 2005 | 10:13 AM
ok its something in the heads when the car idels it smokeds like a bitch but when ur driven down the road at 2k plus it dont smoke a drop if not barley noticable the intake manifold is clean now after i cleaned it and hooked the fresh air house back up.........any way to check the heads
Old Aug 14, 2005 | 10:25 AM
HavATampa's Avatar
Does it give a big poof of blue smoke on start up after it's been sitting all night? Could be worn valve guides and/or bad valve seals.
Old Aug 14, 2005 | 10:56 AM
when u start it up it dont smoke for about 15seconds the gets worse and worse at idel
when u rev it it like cleans it out.
how could i test them
Old Aug 14, 2005 | 01:13 PM
it also does the same thing with ir without the pcv hooked up the problem is somewhere in the heads just got figure it out
Old Aug 14, 2005 | 06:43 PM
i will be pulling the springs and checking the valve seals and guides this week i will updaye
