oily intake runners
Old Aug 11, 2005 | 06:59 PM
SSPerformance's Avatar
Default oily intake runners
i took the fast intake off my car and now the intake runners are like oil coated and if u shine a lite down the runner u can see oil sitting on top of the intake valve. i also had the one line that goes from the valve cover to the tb pluged off and when i took the oil cap of it had about 10psi of crank case presure so i hooked that line back on.
Old Aug 11, 2005 | 07:02 PM
TAQuickness's Avatar
sounds like you need a catch can
Old Aug 11, 2005 | 07:06 PM
oange ss's Avatar
Originally Posted by 1984camaroz28
i also had the one line that goes from the valve cover to the tb pluged off.
that would be the fresh air supply for the pcv system, which needs to hooked up
Old Aug 11, 2005 | 07:15 PM
its hooked up now but why so much oil ontop of the intake valves its making it run rich because its puting oil in it
Old Aug 11, 2005 | 07:47 PM
i also read with the fast 90mm setup that u deff need the catch can setup on 98s
ive also have been runign the clear fuel filter inthe pcv line and it does nothing.
Old Aug 12, 2005 | 02:44 PM
im gona clean up the intake and runners and run it with out the pcv hooke up and see if it cures it
Old Aug 12, 2005 | 03:08 PM
Bill's 02 Z-28 SS's Avatar
Hi Folks
The word here is "OIL CATCH CAN" - it works and will solve your problems.
Bill
Old Aug 12, 2005 | 03:24 PM
i think its a lil more then a catch can to solve this problem posting pics in a few seconds
Old Aug 12, 2005 | 03:29 PM
Default pics
pics uploaded
Attached Thumbnails oily intake runners-fishin-029.jpg   oily intake runners-fishin-030.jpg   oily intake runners-fishin-031.jpg   oily intake runners-fishin-031.jpg   oily intake runners-fishin-034.jpg
Old Aug 12, 2005 | 03:45 PM
1ORANGEWS6's Avatar
Are your plugs black? Did you put thread sealer on your rocker arm bolts? I have the same problem, but my plugs were fouled out and black as hell and intake runners had oil everywhere and I had a vaccum leak that I couldn't find. Well I takked to a mechanic friend of mine and he said that every ported head that he had installed he had to put silicone on the rocker arm bolts to keep them from leaking air and oil into the intake runners. Oil was dripping right on to my spark plugs.
Old Aug 12, 2005 | 03:54 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
Honestly.... that looks pretty typical of every ls? intake I've seen over the past 6 years.
Put a catch can on that sucker because that's where the oil is coming from. Or run breathers.
Old Aug 12, 2005 | 04:14 PM
30th droptop's Avatar
I don't see how a leak at the rocker could get oil into the intake.
And definintely DON'T plug the valve-cover-to-intake hose. This is essential to pull air through the engine when the vacuum side of the PCV system is operating, and even more essential to alow reverse-flow under high manifold pressure conditions.
10 psi of crankcase pressure will blow seals out (are things leaking already?). You might want to use the GM check to see if the crankcase is overpressurizing: Disconnect and plug the valve-cover-to-intake hose (for the test only!). Next, take out the oil dipstick and attach a vacuum/pressure gauge to the dipstick tube. Run the engine at idle for a couple of minutes, then increase the speed to about 1800 to 2000 rpm for about 20 or 30 seconds. At no point in this test should you see pressure on the gauge. And generally, you should see some vacuum at idle. If the test shows you're pressurizing the crankcase, run a compression or leakdown test and try to figure out where it's coming from.
Sometimes, if it's just a little extra pressure, you can get one of the orifice-type PCV "valves" and open up the orifice a bit so that you can draw more air through the system.
Of course, some of you guys with racing engines running 12.5:1 compression will tend to pressurize the crankcase often, in which case you're probably running a scavenging vacuum pump to avoid pressure build-up.
Old Aug 12, 2005 | 06:17 PM
i think i may have found hte problem i changed to the 99 and up valve cover and i could not find a fitting to allow the house to fit in the gromet in the drive side valve cover so i found a pcv valve at work that had noting in it. so i used that and the side the sits down in valve cover only had a hole the size of a pen tip. maybee that whouldent allow enought vacume to pull the presure out of the crank case.
Old Aug 12, 2005 | 08:55 PM
car does not make any crank case presure now but smokes realy realy bad
Old Aug 12, 2005 | 11:43 PM
Blue smoke? It still could be residual oil that puddled up. Run it for a while and see if it gets any better.
Old Aug 13, 2005 | 08:15 AM
Hi Folks
I think that is typical for LS1 and I had the same issue with 3000 miles on the car. A Catch Can will help but may not totally eliminate the problem but it does help.
Thanks
Bill
PS: the only thing I did not like was the oil ring on the head around cylinder # 3 – like it was not sealing correctly
Old Aug 13, 2005 | 08:34 AM
1ORANGEWS6's Avatar
I was told that oil and air could leak through the threads of the rocker arm bolts if you have ported heads. I was told this by a friend of mine that is a mechanic that has built lots of engines and several LS1s.
Old Aug 13, 2005 | 08:55 AM
i used rtv on the rocker bolt when i put it toghter
Old Aug 13, 2005 | 08:57 AM
Originally Posted by Bill's 02 Z-28 SS
Hi Folks
Thanks
Bill
its a little more of a problem then a catch can the car smokes like a train
im goNA do a compressin test top and see what is what
