383 Heads and Cam Help
Old Aug 18, 2005 | 10:31 AM
Black8Banger's Avatar
Default 383 Heads and Cam Help
Ive used the search button to try to find out what cam should be used with a 383 LS1 but Im not finding what I need. I see mainly people using small cams for streetability.
Im looking for a lot of power! The car is a DRAG ONLY car! No street time so streetability is not an issue. I know the MS3, Trex, G5x4, etc. are the big cams for a 346....What is a big spec cam for a 383??
What heads are the big power heads for a 383 stroker? AFR 205s or 225?
Thanks in advance!
Old Aug 18, 2005 | 11:49 AM
SiL3NtXWS6's Avatar
Hydraulic roller, right?
You could go as big as you want ( depending on head flow numbers and how much valve relief you have in your pistons ) .
I run a 261/267 hydraulic roller in my 408 DAILY driver. It's big, but do-able.
Old Aug 18, 2005 | 11:50 AM
Patrick G's Avatar
LS1 Tech Administrator
Cam and heads choice depends on whether you're running an all-stroke 383 or and all-bore 383. Both will perform better with AFR 225s, but the valve events will be different depending on how you got your extra cubes.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Aug 18, 2005 | 12:05 PM
SAM98WS6's Avatar
I wouldnt go any smaller than mine
242/250 .595/595 109
AFR 225 heads are the way to go...11:1 at least...I run 92 octane no problem.
Old Aug 18, 2005 | 01:00 PM
It would be 383 stroker, maybe even a 393 stroker (still doing some researching on the 393 stroker). With the 346 I made the mistake of getting a 228/232 cam instead of going all the way with a trex, ms3, g5x4 or something similar. I dont want to make this mistake with the new setup, I want to go all the way the first time around! I just dont know what is considered big/track only for those setups
Old Aug 18, 2005 | 01:45 PM
Patrick G's Avatar
As you're doing your research on your shortblock, also check to see if it has valve reliefs. I would be shocked if it didn't.
Since you have an all-stroke 383, you'll want about 2 degrees more of LSA than if it were all bore. Why? Because longer strokes and higher R/S ratios increase piston dwell time at TDC, making the engine act like it has increased overlap.
I'd do something like a 242/250 on a 112LSA for an all stroke and 110LSA for all bore. Run AFR 225 heads with the chambers sized to give you the static compression you want.
__________________
Old Aug 18, 2005 | 03:15 PM
SAM98WS6's Avatar
Exactly right...I did the 109 for sound only since i dont drag race much...another 10+rwhp left on the table with a 112 I bet. But mine sounds damn mean....
Old Aug 18, 2005 | 03:39 PM
ta_silver_bullet's Avatar
how do these cams that yall are saying to use act on the street ( not meaning to hijack your thread black8banger) i am in teh market for a new cam myself for my all stroke 383
Old Aug 18, 2005 | 04:16 PM
ta_silver_bullet: what kind of 1/4 times does your 383 setup run? and what kinda power is it putting out?
Patrick: What kinda lift is a good lift for a track only 383 all stroke? Also, since you know your converters, what stall would you suggest for that setup (also lockup or nonlockup?)
Thanks guys yall are a big help!
Old Aug 18, 2005 | 04:24 PM
no dyno yet im trying to wait to install my TNT kit first so i can get NA and N2O runs. i made 375rwhp/372rwtq with all the same mods just no 383. i am still using a VERY small xe-r224 cam on my 383 along with stock LS1 heads becasue i broke a valve spring and it put a gash in the piston. so i just went ahead and forged the bottom end and stroked it at the same time, but i figured i would upgrade heads and bigger cam later. as far as track times my car weighs 3900 pounds race weight with me in it i ran on 245 street tires (no traction with teh 383 now). i ran a best of 12.7 @108 with a 1.9 60' before the 383. with the 383 crappy track conditions 60' was 2.2 and i ran a pitiful 13.0@112mph. i figure the way teh car sits now with dr's or a et streets i would get low 12's with a decent 60'. my 383 isnt at all impresive yet and i feel that is becasue of the small cam and stock heads i had to use, but i didnt expect anything more from it yet i just did it and knew when i upgraded later it would all work out
Old Aug 21, 2005 | 10:12 PM
kevredz's Avatar
Thanks in advance!
I'm running the MTI 2R's and the R1 camshaft (more of a driveability cam) in my stroker 383. I'm curious to what "track only" cams work the best with the 383 also.
Old Aug 22, 2005 | 12:20 AM
1QuickT-A's Avatar
Local guy here in AL is running a 383 stroker with AFR 205's, Fast 90/90, with the TSP "Giant" cam and he put down 506rwhp thru a T-56 and a 9in..
Old Aug 22, 2005 | 12:33 AM
kevredz's Avatar
Now that's a cam.
Originally Posted by TSP website
TSP Texas Giant Cam: 248/254, .629"/.622", 113 LSA
2200-6600 RPM Power Band with 400+ cid engines; This cam is designed for the larger cubic-inch engines and is NOT for stock-cid applications
Old Aug 22, 2005 | 12:35 AM
what numbers did you put down and whats your track times if you dont mind me asking
Old Aug 22, 2005 | 12:37 AM
how steetable is the car with that cam i know its pretty damn big
Old Aug 22, 2005 | 12:44 AM
kevredz's Avatar
I'm running 11.3-11.5's at 118-121 depending on the DA(1000-3000). I put down 390 SAE corrected rwhp and 550 rwtq (A3 dyno #'s) I need a re-stall, the converter is a little too tight. I'm hitting 1.65-1.70 60's.
Old Aug 22, 2005 | 12:47 AM
nice. i had my 383 built and i instaled it but i didnt have enough cash to do heads and cam so its a 383 with stock ls1 heads and a xe-r224cam lol. i had to at least rebuild my stokc motor so i figured while it was aprt i would stroke and forge it so now im looking into heads and cam for it and still be very streetable
Old Aug 22, 2005 | 01:01 AM
kevredz's Avatar
I did almost the same thing. I spun a rod bearing on the stock motor so I purchased the 383 short block and ran it with stock heads. It ran 12.0's at 115 with the stock heads, R1 cam, and the 6spd with 1.8 60's. I installed the MTI 2R heads and the TH350 and it dropped me 6-7 tenths. I don't think the Th350 help my ET. It was the 2R heads that really helped me out.
Old Aug 22, 2005 | 01:08 AM
DONAIMIAN's Avatar
Have you taken a look at TSP's texas giant.
Old Aug 22, 2005 | 01:13 AM
kevredz's Avatar
I have heard about it. I really would want to give MTI a shot at it before I go with another shops cam, but I am always open for suggestions.
It seems like a hell of a cam. I like the power band. My rev is at 6600.
