Has anyone done an F11 cam advanced +2 or +4?
I did search by the way, and only found like one guy.... so maybe I can flush you others out!
Looking for someone who has installed (with adjustable timing set) an F11 (or even F13) +2 or +4 degrees advanced. Did you have good low end with the advance ? How was the piston to valve clearance?
Thanks!
Thanks!
P2V is usually pretty good with both cams. From what i was told today, all futral cams come with a +4 advance. As far as the chain, if it will clear the pulley then there shouldnt be a reason you cant run it...
Nino
Nino
no prob....actually, when talking to one guy at futral, he told me that that was another option and that a few guys have done it when they got their cam installed cause they wanted a +2 advance, but didnt wanna wait for a custom cam to be grinded.
