My C5R flow numbers
Old Aug 19, 2005 | 08:17 AM
DAPSUPRSLO's Avatar
Default My C5R flow numbers
These are the flow numbers from my heads. They did not CC the intake or exhaust runners, but the combustion chambers are 37 cc . I've gotta run a turbo piston just to get the compression down, funny stuff. In any event these are very average on the intake side, and a little below average on the exhaust. Erik is going to talk to his cylinder head guy to see what can be done on the exhaust side, and maybe the intake as well. Valve size is 2.18/1.62. Here ya go.
Nick,
I just got the flow data in on these C5r heads.
Heads flowed as follows on a 4.155 bore:
Intake:
.100 67
.200 150
.300 222
.400 295
.500 341
.600 368
.700 367
Exhaust:
.100 43
.200 111
.300 168
.400 207
.500 222
.600 227
.700 231
Erik Koenig
HK Enterprises /
Horsepower Engineering
6915 Breen Dr.
Houston, TX 77086
Ph. 281-448-1300
Fax 281-448-1305
Old Aug 19, 2005 | 08:21 AM
Patrick G's Avatar
LS1 Tech Administrator
Nick, those are some killer numbers! Look at thos numbers at 4 and 5. Yikes! You're in very good hands with Erik. He's surrounded by talent (including himself). They'll get those heads knocking down even bigger numbers I'm sure.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Aug 19, 2005 | 08:35 AM
DAPSUPRSLO's Avatar
Yeah, I can't wait to get these on mr. 434, woohoo. Shooting for 11.5-11.9 to 1 though. Was going to keep it around 11.5 to 1 but may go a little higher as the ve of these heads may not be as good as we orignally thought because of the larger ports. Erik seems to think the head ports are pretty big (270s or so) but no one knows for sure until he or someone else cc's them.
Old Aug 19, 2005 | 08:51 AM
DAPSUPRSLO's Avatar
Oh, and btw, if any sponsors would like to take a crack at these for porting purposes please feel free to chime in. I've already looked at one sponsors flow numbers on a 4.155 bore and they were below mine from .300-.600 about 5-10cfm but smashed mine from .600-.800 by 5-25 cfm with a 255 cc port. Anybody who thinks they can improve these by all means let me know. Not looking to spend more then $500-800 for additional work though. Thanks.
Old Aug 19, 2005 | 09:03 AM
Patrick G's Avatar
Honestly, I wouldn't look at the intake runner cc volume. With the 11 degree valve angle and different port configuation, they're going to be bigger than the LSX stuff anyway. I'd be more interested to see how the cross sectional area compares to some of the higher flowing LS6 heads out there. Erik and his buddies at SAM have gotten some LS6 heads to flow like wind tunnels. Maybe they could chime in and compare the cross-sectional areas between the two heads.
Old Aug 19, 2005 | 09:18 AM
DAPSUPRSLO's Avatar
I spoke with Erik (edit: spelling) about those heads too, I think their cross section is a good bit less though and they don't stall out like mine do. I believe the 11 degree stuff has a longer port which will automatically increase volume so you're right. But I'm comparing other 11 degree stuff so it is a valid comparison. Good point though Patrick.
Old Aug 19, 2005 | 10:40 AM
JZ'sTA's Avatar
Every thought about selling the heads you have and buying some already done?
The ET performance heads might be a awsome option.
I haven't seen any results yet buy they have some impressive flow numbers, many different cc option's, still use a 11 degree valve angle, and they have both LS7 and C5r aftermarket castings available.
Old Aug 19, 2005 | 10:46 AM
DAPSUPRSLO's Avatar
I just got off the phone with them. I may send them these heads depending on what I here from a couple of options. Thing is I couldn't get out of these heads what they are worth and justify the added expense of a new set. The heads I have already have Del West titanium valve which are about $1300-$1600 by themselves. I think my best option is to send these heads to someone and have them worked. HRD, ET, guy in Texas, etc. are a few options.
Old Aug 19, 2005 | 12:27 PM
99SS-T's Avatar
2.18 thats nuts
John
Old Aug 19, 2005 | 12:45 PM
DONAIMIAN's Avatar
The flow numbers are good compared to everything else, but I could see more flow out of the head.
Old Aug 19, 2005 | 01:28 PM
Tony Mamo @ AFR's Avatar
Flow Wizard
If those numbers came off a bench known to provide accurate info I wouldn't lose too much sleep. The peak intake numbers might be slightly below "average", but assuming the ports aren't monstrous in size, those type of "real world" numbers aren't too bad. The exhaust might pick up 25-30 CFM's with a pipe (or they might only pick up 10-15), so it's kind of hard to make a judgement call on the exhaust flow.
Once again, alot of the C5R flow numbers I have seen thrown around in the Matrix (390,400 Etc.), are alot higher than I, or other bench's I trust have shown. Almost 370 CFM of "legit" intake flow (with good midlift #'s) will make a buttload of power. Thats some serious airflow for ANY SBC style head. Alot of BBC small and medium sized aftermarket heads would have a hard time keeping up.
Thats my .02
Good luck with the build...
Tony M.
PS....I'm not claiming a C5R head can't go high 300's, it's just going to be more the exception than the rule if you were to take a cross section of people that own them....especially those C5R heads in the hands of "Average Joe Racer" (someone not spending stupid money on a set of "one off castings", etc.).
Old Aug 19, 2005 | 01:39 PM
DAPSUPRSLO's Avatar
Heads were flowed by HPE's machine shop so I have the utmost confidence in the reported numbers. I just wish I knew the port size but hopefully I will soon. Thanks for the input guys. Trust me, I'm not giving up on these heads by any means.
Old Aug 20, 2005 | 10:44 PM
Cary@Perf-Induction's Avatar
Collections Hold
Default c5r
Thats my .02
Tony M.
I agree with Tony. Those are crazy mid numbers. We did a set like that recently, and You can't give up those very usable mid numbers. We did the AFR heads on W2W's turbo car and those didn't have near the numbers that your c5r's have and still laid down a 6.80 pass. granted it is a turbo. but those kind of numbers are good for over 750 HP n/asp. Our C5R style casting doesn't have the problem falling over as soon because we raised the intake port another .750 over the current C5R casting. The 11 degree will tend to roll over a little sooner because of the flat valve angle.
Old Aug 21, 2005 | 12:21 AM
DAPSUPRSLO's Avatar
Thanks for the reply Cary. I called and spoke with Craig. I may send these over to you guys to see what ya can do with em.
Raising the port may not work with my setup as I have a modified sb2 manifold that will go on these. I've not seen any of it in person yet though as it's over at HPE so maybe a raised port would be fine with the intake setup. Kind of doubt it though as the intake has been worked heavily for these heads. Well in any event should be interesting.
Old Aug 24, 2005 | 12:49 PM
airflowdevelop's Avatar
Just browsing around, and thought I would throw my .02 even though I am not a sponsor...but have played around with these heads once or twice
I would "guess" that you need to take another look at the SSR and venturi. If the port is in the 270's you are fairy short with a 2.18 valve. Most of the new programs in the middle 280's will go 109 cfm/sq" so you are pretty short for an all out head. I would bet your airspeed off of the floor is 350+ FPS. need to get her slowed down a bit, and the rest should come around. your exhaust problem is more than likely in the chamber. Ask Erik what the intake port sounds like. If you need any further help, feel free to shoot me a PM with some more specifics.
Thanks
Dennis
