My 'G5X3' experiance
Man this sucks. I would be pissed, there goes about 5hrs of work.
Dixit
How the heck can you degree the cam in without a cam card?
Ed
FWIW - I ordered a custom cam and received no card and know at least two others where this happened also.
John
John
And even if you did, changing oil pumps isn't going to make it more likely to fail, so long as you are carefull with the O-ring.
When parts don't look right, it's a good idea to call the sponsor first just to double check. I had a similar experience when I had a cam shipped directly to my mechanic. I saw the cam card after it was installed and discovered that it was not what I ordered.
You seem to know what you're doing....so too much luck is probably not required
Are you going to have it tuned and dynoed soon thereafter?
